is a small suspension lift possible
Discussion in 'Lifted & Offroad Suspension' started by 95WT, Sep 15, 2009.
  1. 95WT
    95WT Member
    when i jacked up my 95 C1500 the other day to check the brakes, i thought it looked pretty cool after 2 or 3 inches of being jacked up, nothing big since it is 2WD, but still looked cooler
    anything would be nice, and yes the bushings do look worn but arent squeaking
    or can i find a decent stock 16 inch rim for a bigger tire :)
  2. vncj96
    For you all you need is a 2-3" spacer on the coil spring up front to bring it level. You can also add blocks to the rear if you want to raise that too, either way it will be pretty cheap for you to accomplish.
    Try: fabtech, rough country, skyjacker and stylintrucks
  3. 95WT
    95WT Member
    sweet, i know where i can get the coil spacers, and the fleet farm in town has leaf spring boosters too
    what about what i should look for when i change the shocks and struts?
