Is there something bent in my drive line?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Fine Burban, Nov 3, 2013.
  1. Fine Burban
    Fine Burban Member
    I noticed last night on the drive home that when going 30 MPH and giving it maintenance throttle that it seems as if the Driver side rear (may be passenger as well) moves up and down to give it a bouncing feel, but as soon as I let off the throttle it goes away completely. @30MPH I am in 3rd gear on a 700R4 Trans. Any ideas would be greatly appriciated.
  2. summitwhite11
    summitwhite11 Active Member 2 Years 500 Posts
    I normally look to u-joints and carrier first, curious, off road or street driving .
  3. Fine Burban
    Fine Burban Member
    Street driving, but I have only owned the truck for about a month now and still finding issues with it. I checked the U-joints this past weekend for slop or excessive wear. I didnt really see anny but I will be replacing them soon when time and money is available. Thanks for the input, maybe I just over looked something.
  4. BurbanMan
    I originally though about wheel/tire/shaft balance but then I read that it stops when you get off the throttle.
  5. Fine Burban
    Fine Burban Member
    Yeah that is what I was thinking as well but it legitimatly feels as if the back end of the travels 1.5-2" up and down when maintaining speed arounf 30 MPH and 15 MPH since those are the the 2 speed limits on my way to and from work.
  6. summitwhite11
    Thinkin it would be worth swappin one tire/wheel at a time on the rear to prove there is no tread seperation or related wheel issues, its going to be a process of elimination anyway, balance is normally a vibration that will increase with speed,tread seperation will deliver vibration and or bounce.
  7. Fine Burban
    Fine Burban Member
    I will experiment this weekend since I dont think I will have time durring the week to try that so I will keep this thread updated. Thanks for the idea.
  8. j cat
    with the axles free to rotate check for bad bearings and axle U joints. check pinion bearing at the rear diff. check for rear wheel bearings to be tight also if bad these usually leak.
  9. Fine Burban
    Fine Burban Member
    I just replaced the rear shoes and hardware kits in the drums and didnt notice any excessive play in either axle but I did not look at the pinion gear bearing.
  10. BurbanMan
    if the tread were separating, he should be feeling that at all speeds. Week at first and more violent as speed increases. SHOULD being the key word lol
