is this battery isolator worth the money?
Discussion in 'GM Electrical Tech' started by dadtruck, Sep 9, 2012.
  1. dadtruck
    dadtruck New Member
    I hope this is the right forum......
    I'm looking to build a dual battery system for my truck and I've been researching battery isolators and I found these: in power battery isolators.
    is this a good idea to buy? It seems like it might be more reliable because their solid state....
    - - - Updated - - -
    some more info...
  2. SurrealOne
    Solenoids are the least reliable form of isolator but also tend to be the cheapest ... and are usually reliable enough for stereo applications. Diode-based isolators are a little more expensive and are highly reliable ... but they entail voltage drop due to the use of the diode ... which affects your ouput. MOSFET-based isolators are spendy but are ultra-reliable and have negligible voltage drop. By 'solid state' I'm assuming that isolator is MOSFET-based.
    Choose your approach based on budget and application requirements; there's no lone right/correct answer. You might ask them what they're using for the isolation before buying...
