It just died
Discussion in 'GM Powertrain' started by Gbav1, Feb 9, 2009.
  1. Gbav1
    Gbav1 New Member
    Hey Guys&gals, newbee her and I have a Question for you guys, I was going down the interstate about 70mph yesterday, and my 2006 s1500, with a 4.3V6 just died. I tried to restart, and the motor would just spin but not fire. I checked the sparkplugs and no fire at all. I have voltage at the ICM and at the Coil. I replaced both the coil and the ignition control module, still nothing (no spark). Also no codes are showing up on scanner. Truck has 50,000 miles on it. and of course its out of warranty.
    Any suggestions would be greatly appreciated.
  2. 05azsilver
    05azsilver Rockstar 100 Posts
    I see that you have no spark, but is that from the coil or to the wires?
  3. justcurious
    justcurious New Member
    You might want to perform a compression test, or just pull a plug and put your finger on the spark plug hole and see if it blows back. Does the truck crank over a lot faster now, after the stall and die. Could be the timing chain failed. If not,you really need a scanner that will show live data, to see if you have reference RPM going to the computer. Without reference signal, you would have a ignition problem. You can buy a scanner that shows live data, at autozone for about $150.00. Get back and tell us what the problem was once it's fixed. Good Luck.
  4. Gbav1
    Gbav1 New Member
    I have spark coming out of the coil, but not at the sparkplugs. I put a new accel hp distributor cap and rotor on today and still nothing. Scanner shows no codes.
  5. jlsparky7
    jlsparky7 Rockstar
    Before you get ahead of yourself try to rule out what the problem is. You need compression fuel/air and spark for ignition. Make sure you have all of those first. Could be as simple as a fuel pump/filter.
  6. Gbav1
    Gbav1 New Member
    Been there done that!
  7. TMRuiz
    TMRuiz Rockstar 100 Posts
    If you have spark coming from the coil but not from the plug wires you might have a busted dist. pull the cap and spin it it over to see if the rotor is spinning. If you changed the rotor cap plugs and wires but still have no spark from the wires it's a good chance that rotor isn't spinning to transfer spark to the plugs.
  8. Gbav1
    Gbav1 New Member
    Found the problem, it was the pin connector (12volt) that plugs into the coil. When I checked it for voltage, it had 12volts, but when it was plugged in it was sending less than 12volts to coil, so I was getting spark to the distributor but it was weak. Never had a connector on a vehicle in 38 years of owning cars and trucks ever do that before. So much for buy American.
