It's HOT outside! *Rearview mirror temp readout content*
Discussion in 'General Chevy & GM Tech Questions' started by HolySloth, Dec 27, 2010.
  1. HolySloth
    HolySloth New Member
    So the compass works fine on the rearview mirror, but it tells me that it's well over 100 degrees almost all the time. It was about 40 out this morning, but the mirror said it was 122. :shocked:
    Whazzup with that?
  2. mfleetwood
    Is this regarding the '99 burb?
  3. randomsandwhich
    randomsandwhich Rockstar 3 Years 100 Posts
    Just to comment, Mine does same thing. Especially with defrost on, max heat and max blower. I think it messes with the sensor sometimes. Once you start driving the temperature becomes more realistic. Don't think its a defect just the location and how the sensor reads outside air.
  4. HolySloth
    It is. '99.
    ---------- Post added at 09:28 AM ---------- Previous post was at 09:21 AM ----------
    Not mine. It goes down a few degrees, but I've never seen it below 88.
  5. mfleetwood
    I'm not familiar with the burb's or that year, but I had a '97 sierra in which someone had installed an aftermarket temp/compass mirror.....and they mounted the outdoor temperture sensor too close to the radiator. That could be the problem if the gauge reads correctly when first starting out and then maintains the high temp after the engine is warmed up. If it starts out wrong to begin with, you might need to replace the sensor.
  6. HolySloth
    That makes sense. I'll probably just replace the sensor at some point. Till then, I'll just pretend I'm actually driving in the Bahamas.
