keep losing voltage
Discussion in 'General Chevy & GM Tech Questions' started by tnchevy, Jun 25, 2009.
  1. tnchevy
    tnchevy New Member
    my 03 silverado keeps dying and i put in a new battery and tested the alternator. not sure what else to look for, my battery gauge keeps going up and down and the truck idles weird. it gets really bad with the a/c on. not sure if this is a common problem but could really use some help.
  2. redneckarmyMP
    redneckarmyMP Epic Member 5+ Years 500 Posts
    if its a new battery id try a new alternator anyway..sombody else might be able to help you a little better though
  3. 2COR517
    I would start by making sure your connections are clean. Battery, alternator, the big grounds. If that doesn't fix it, sounds like a bad alternator to me. Is it better when the truck is cold? Then get worse as the engine warms up?
  4. Springthing
    ^^ What he said x2 ^^
  5. tnchevy
    tnchevy New Member
    i guess u could say that it's worse when it warms up. if i have the a/c off i can drive for a few minutes before it cuts off. it starts right back up and will go a little farther then cut off again. when i just crank it up and turn on the a/c it just idles up and down and almost cuts off. i thought it might be the alternator cuz sometimes when they test ok they can still be bad.
  6. Jimmiee
    Your alternator won't cause your truck to die unless the battery is dead. Does the problem happen after the battery is charged?
  7. tnchevy
    tnchevy New Member
    it died with a new battery. i just tried an alternator and it still idled wierd. does anybody else have a suggestion?
  8. 1st Synthetics
    Ground connections is where I would start.
  9. Jimmiee
    X2 on ground connections. Has anyone worked on the truck before this problem happened? If so that's where I would be looking. Engine repair, alarm, stereo, accessories? Any of these repairs done lately? If so that's where you will find your problem.
    You never mentioned if you checked for codes. On today's vehicles this is the very first step on ANY kind of an electrical or mechanical problem.
  10. tnchevy
    tnchevy New Member
    no codes. i'm about to go back out and work on it. i've never had it worked on. this is the first problem i've ever had. i'll keep u guys updated.
