Key Buzzer Won't Stop
Discussion in 'Chevy C/K Truck Forum' started by Bigg Ron, May 16, 2010.
  1. Bigg Ron
    Bigg Ron Rockstar 100 Posts
    On my newly aquired 99 C2500 Crew Cab I had to replace the battery, so after the battery was in I strated the truck and the key buzzer would not stop buzzing, I checked all the doors to make sure and made sure my sealt belt was buckled and still it was buzzing, only removing the key stops the buzzing. Any Suggestions?
  2. vnslykrx
    vnslykrx Rockstar
    I don't know if yours is the same as mine, but have you tried the lights? If yours has a dial on it, turn it off and see if that does anything It happens on mine every once in a while and that seems to work. If its not that, check the fuses and maybe some connections.
    Good luck, Ryan
  3. pychokenny
    pychokenny Rockstar 100 Posts
    Theres a box under the dash near the flaser reley it square pull it. But u wont knew if u left ur lights on on if the key is in it
