key doesn't work i'm losing my mind
Discussion in 'General Chevy & GM Tech Questions' started by bassalive, Nov 26, 2008.
  1. bassalive
    bassalive Rockstar 100 Posts
    I just purchased a 1999 Tahoe and posted some problems I was having with the front doors remote locks not working. I figured "what the hell" if the key works thats fine. I tried all the locks and the key does not work! I am assuming that the doors have been replaced as well as the hatch. What I would like to know is it possible to have keys made that fit or do I need to replace the whole door lock shootin match?By the way, the remote does slightly move the front latches and it unlocks the rear doors and the hatch??
  2. Howie
    Howie Rockstar
    A locksmith might be able to create a kay based on a vin, but seeing as how it has been replaced, I fear you might be screwed man.. :shocked:
  3. bassalive
    Thats what I thought. Oh well I'm on my 10th Alpine so who gives a f!@#$. Thanks man.
  4. retired
    retired Rockstar 100 Posts
    If you key doesn't work the doors or the gate most likely the ignition switch was replaced.
  5. bassalive
    You have a point there. Any ideas on the chapest way out? and why does the key fob work on the rear doors and gate but not the front doors?
  6. retired
    Buy a lock set and replace all the locks, by the time you have a lock smith rekey everthing it's cheaper to put in a lock set. As far as the door lock actuators you will have to pull the door panel to see if you are getting power to them.
  7. bassalive
    Thanks. I'm getting power because the move slightly when pressed?
  8. retired
    Then the actuators need to be replaced.
  9. bassalive
    thank you. How do I deal with the key situation?
  10. vncj96
    keys will have to be done at dealership $$$, nyou can first try and have the remote checked or reprogrammed while you are there too
