Key Stuck 1999 Yukon
Discussion in 'General Chevy & GM Tech Questions' started by doubledb, Jul 14, 2009.
  1. doubledb
    doubledb New Member
    Does anyone have any suggestions on how to fix my stuck key problem. I pulled the dash on my 1999
    Yukon and when I put it back the key does not want to go into the lock position. It will start and run but when I turn it off it does not go far enough, the light on park, drive, etc is still on. Also the shifter is not as smooth as before. I have to play with it a little to get it in and out of park. I loosened the bolts holding the [COLOR=blue !important][COLOR=blue !important]steering [COLOR=blue !important]column[/COLOR][/COLOR][/COLOR] on and moved it forward and back and it didn't make any difference.
    Any help will be greatly appreciated.
  2. Jimmiee
    Your linkage is in a bind. Loosen the linkage at the transmission. Put it in park and make sure the key will come out. Now tighten the linkage back up and it's now adjusted.
  3. doubledb
    doubledb New Member
    Key Stuck
    Thanks I'll give it a try.
