Knock,knock
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dfhollums, Nov 17, 2012.
  1. dfhollums
    dfhollums Rockstar 100 Posts
    About 8 months ago upon first start up of the day of my '00 Silverado (5.3 V-8), or even after sitting a while having a chance to cool, I hear a light knocking sound coming from the engine. It goes away after the engine is warmed up and the fluids have had a decent chance to circulate, but the knock has gotten worse either. What do you reckon?:neutral:
  2. 1953bowtieguy
    1953bowtieguy Rockstar 4 Years 500 Posts
    Have you checked your timing? Cuz if the timing is "Retarded" to far it can do that.
  3. Pikey
    It could be piston slap or a rod knock. My 02 would knock when it was really cold out until the motor warmed up. I would let it idle until the knock stopped and then drive, it did not get worse over time though
  4. dfhollums
    You described my truck's problem to a "T".
    - - - Updated - - -
    I never thought about the timing, but I will give it shot. Mr. Plikey described my truck's problem to a "T".
  5. redvett
    redvett Rockstar 100 Posts
    Timing on any GM truck engine after 1995 is computer controlled.You have the cold start knock and its just fine.
    - - - Updated - - -
    I never thought about the timing, but I will give it shot. Mr. Plikey described my truck's problem to a "T".[/QUOTE]
  6. stchman
    What oil filter do you use? I've had Chevy trucks for some time and unless I used a GM oil filter, I got a brief knock on start-up.
    If you don't use an AC PF-48 I highly suggest you do as they cost about the same.
