Larger tires and speedometer/odometer variation
Discussion in 'General Chevy & GM Tech Questions' started by Boxman7481, Oct 22, 2009.
  1. Boxman7481
    Boxman7481 Member
    With larger than stock tires installed on my Colorado the speedometer is 4-5 MPG less than actual at speeds of 65-75 MPG (checked with GPS).
    How does this affect the odometer? Am I putting more miles on my truck than actual??
  2. daweinah
    daweinah Rockstar 100 Posts
    Hmm, your wheels have a larger circumference, so they are traveling further per every rotation of the wheel, so I think your odometer would actually read less?
    EDIT: So yes, if your wheel circumference got 10% longer, you will have traveled 110 miles when your odometer says you've been 100. Would probably throw off your DIC readings too. Wonder if that can be adjusted..?
  3. Thundare
    Thundare Rockstar 100 Posts
    Yes this can be done by changing the gear in i think the transfer case to match the size of your new tires.
  4. XS ive
    XS ive Rockstar 100 Posts
    I believe you can also modify the ECU to compensate for larger tires by changing shift points as well as speedo/odo readings??
  5. canislupis69
    You can adjust for the tire size (and gear size if you ever change gears) with a hand held tuner. I used a hand held tuner to adjust my speedo for my 35 inch tires and my gear change from 3.73 to 4.56. I used a garmin and kept adjusting with the hand held until my speed was dialed in perfect.
