Leak under carpet in extended portion... and it's freezing up!
Discussion in 'General Chevy & GM Tech Questions' started by boris_thespider, Dec 14, 2010.
  1. boris_thespider
    boris_thespider New Member
    There appears to be water leaking up under the carpet in the back seat area of my 2008 extended cab. It's in the center... right behind the cup holder. At first, it looked like something had been spilled on the carpet. It was about 2 inches in diameter and it was hard. When I was trying to clean it, I noticed that it was frozen (it's only 18 degrees here in western New York). So, I got out the wife's hair dryer and a rag to thaw it out and clean it up. There was no smell or residue as it thawed. It appeared to be just water and after about 15 minutes with the hair dryer, the hard, icy spot was gone and the carpet is dry. Has anyone ever had a spot leak under the carpet in the center of the floor like this? How did the dealer fix the problem? Thanks...
    NEVER MIND,,,,thought about my truck..sorry
  3. boris_thespider
    I would think that there would be hot air ducts coming from the front.
  4. canislupis69
    I had the same problem, but the water was closer to the doors rather than the middle of the truck. It turned out my 3rd brake light was leaking when it rained. Replaced under warranty.
  5. murdog94
    And or else the rear window isnt seated properly and leaking.. There isnt a heater core for the extended or crew cab trucks just ducting to the rear.
  6. Bigbomber
    I would think that your dealer would run a high pressure water test on the cab of the truck to find the leak.They found a pinhole on the gasket around my windshield on my Uplander by checking for leaks this way.
