Leaking... again...
Discussion in 'Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)' started by Conlan Rose, Sep 27, 2012.
  1. moogvo
    If you heat it, it will weaken it and will need to be replaced. Also, trade in your WD40 for some PB Blaster. I haven't found a bolt it won't free yet! You may have to use air to break it loose. Just know that there is a chance of wringing the bolt head off using air if the bolt is corroded badly. LOTS of PB Blaster! I bought a gallon container that came with a refillable metal spray bottle. It's REALLY happy stuff!
  2. Conlan Rose
    Ok, sounds like a plan. Anyway I don't have access to air tools at the moment.
  3. Conlan Rose
    I began work currently the bolts are soaking in WD40(sorry [MENTION=12002]moogvo[/MENTION] its all I have and my transportation is currently well taken apart) I'm using a socket that is 6 sided not 12 so it is snug on the head of the bolt and the t-case is engaged. Gonna give it my all.
  4. moogvo
    Oh... I see that you are living in one of the states that have salty snowcone flavored streets... Yeah... it's gonna be a project to get them out!
  5. Conlan Rose
    Yup, gotta love CT, BTW found this old can of Marvel penetration oil and grime remover I'm gonna see if it also helps.
  6. moogvo
    It certainly can't hurt anything! How does the zurg (grease fitting) look on it?
  7. Conlan Rose
    Hard to tell I'll take pics once its off since the WD40 and Marvel worked with some help from a steel pipe and some arm strength. :glasses:
  8. Conlan Rose
    New problem it seems I do need to remove the cross-over pipe but thats isnt really an option since the only removable bolts are on the exhaust manifold and the rest is a welded system, not modular so you can't just pop it off.
  9. Conlan Rose
    Ok it is an option just the nuts don't wanna go anywhere, wonder why? :lol:Is it ok to spray WD40 on the exhaust cuz ik its flammable and that just doesn't sound like a great idea.
  10. Conlan Rose
    Well no progress.. snapped an extension in half so now I'm **** out of luck. I don't know What to do.... I just can't fix her... I'm ready to just get rid of this thing... I have no drive to fix it any more its not worth the stress.
