Leaking Autotrac
Discussion in 'GM Powertrain' started by dcriffle, Feb 4, 2010.
  1. dcriffle
    dcriffle New Member
    What would make fluid leak from the two rear speed sensors on a 2000 silverado, 5.3 transfer case? If it is the vent, the hose disappears up in the rear engine bay. Thanks.
  2. Jimmiee
    The first thing to do is pull the fill plug and see if it's overfull. If it is you may have a bad seal between the transmission and transfer case. If it is overfull it will blow fluid out the vent. If not the speed sensors will leak because the o ring shrinks over time.
  3. gmfreak
    gmfreak New Member
    I haven't seen sensor o-rings leak that much, but I have seen many snap rings inside the rear case half wear a hole in the rear case, it will be on the right side half way up.
  4. dcriffle
    dcriffle New Member
    Thanks for the advice, guys. I checked the vent and it was clear and the fluid ended up being about 13 mm low. I cleaned the case and filled it with Autotrac II and we'll check it again later and post it. I read (somewhere) that heavy towing will blow some fluid, can't remember where though.
  5. sc99z71
    sc99z71 Rockstar 100 Posts
    Is that True??? Whenever I tow my travel trailer (~5k-5.5k) after a lond drive there is "fluid" on the tow chains and anything hanging low behind the truck. I have never been able to find out what the heck is going on. I dont have any leaks (none that I know of), and the "fluid" on the chains never smells like oil. Could what you were saying about the autotrak fluid blowing out during heavy towing be my mystery problem, and if it is, is it a problem?
  6. sc99z71
    Anyone?????
  7. Jimmiee
    Your transfer case should never blow out oil under any circumstances. If it does you have a major problem!
    Usually when oil is seen after heave towing it is coming from the transmission because the transmission is overheating. A hot torque converter is what makes the oil vent out and blow back. The reason the torque converter gets hot is because towing in overdrive with a heavy foot keeps the torque converter from locking up.
  8. sc99z71
    I always tow in 3 and never in D, even on the interstate (~60-65mph). This will be the first summer of towing the camper with the new shift kit, so we'll see how she does.
