Lift Kit Questions
Discussion in 'Chevy C/K Truck Forum' started by 96GMCSLE, Dec 6, 2013.
  1. 96GMCSLE
    96GMCSLE Member
    I am looking to buy a Rough Country 3" suspension lift kit for truck that already has a 2" body lift. Rough Country recommends using 285/75r16 but if my truck is lifted 5'' total what size tires should I be using?
  2. dsfloyd
    you typically need 6"+ to run 35's. So 33's should be easy and 35's possibly with some trimming.
  3. 96GMCSLE
    96GMCSLE Member
    34's would be pushing the limits?
  4. dsfloyd
    might be getting there but I know sometimes rubbing can be avoided or caused based on the amount of backspacing on the wheels and tire width. Maybe someone with a similar setup will chime in with what they have fitted.
  5. 96GMCSLE
    96GMCSLE Member
    ill probably get 295/75r16
  6. dsfloyd
    That tire should fit with the combination you have
  7. 96GMCSLE
    96GMCSLE Member
    Ok :) thank you!
