Discussion in 'Lifted & Offroad Suspension' started by hdb0002, May 20, 2010.
  1. hdb0002
    hdb0002 New Member
    Whats the easiest/cheapest way to get 2", maybe 3", of lift on an '04 2500hd without getting a body lift?
  2. kburb
    a bodylift will be the cheapest.
  3. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    He's right. A body lift is the cheapest way to lift a truck two or three inches.
  4. adampaul1964
    He said without getting a body lift. The easiest way would be to get new torsion keys and rear lift blocks. New keys will give you 2"-3" and block size depends on what look you want, level or factory rake. Keys can be had from $60 to $230 depending on brand and blocks with U- bolts should be around $100. I chose Pro - Comp torsion keys, I think ypou can get them at stylin' concepts for $219 and I got 3" lift blocks from Fat Bob's Garage for around $100 Kits & Accessories&partfamilyid=5576
  5. hdb0002
    hdb0002 New Member
    Sweet, thanks for the links adampaul. I think im def gonna go with the new keys. What are the pros/cons of add-a-leaf vs blocks?
  6. adampaul1964
    Add-a-leaves will stiffen the spring giving a stiffer ride and a little more payload capacity, blocks will just make it sit higher with same ride and capacity.
  7. Pete95Sierra
    Agreed with adampaul, but I would just go with an add-a-leaf over a block. A block causes more axle wrap and does nothing for your payload or anything. An extra leaf will add payload capacity and help support the stock springs while still giving lift.
  8. silveradotrailblazer
    X2 what AdamPaul1964 and Pete95Sierra said.
  9. hdb0002
    hdb0002 New Member
  10. hdb0002
    hdb0002 New Member
