Lifter tick under warranty?
Discussion in 'GM Powertrain' started by UpsetProps, Apr 7, 2014.
  1. UpsetProps
    UpsetProps Member 2 Years 100 Posts
    My 2012 4.8L Silverado has developed a bad lifter tick @ 26,000 miles. I bought the truck brand new. I have always done oil changes at the dealership at regular intervals. I have used a Diablosport tuner on my truck.
    Would the fix for lifters generally be be under warranty?
    My tuner is broken, so I can't take the tune off. Will this void warranty?
  2. summitwhite11
    summitwhite11 Active Member 2 Years 500 Posts
    There are many opinions around dealerships and tuner effects on warranties, I have found it best if you do some recon with your service guy prior to needing work if you have a tuner installed, just ask him straight up, they will tell you the boundaries and limitations, once you install it, the foot print is there, how ever, not being able to reset factory settings is going to be a handicap if your service guy says it could/or will effect your factory warranty. ( at 26k and a 2012 model that would be a warranty item).
  3. Chesters
    Chesters Well-Known Member 2 Years ROTM Winner Gold Member 1000 Posts
    Just had a friend with lifter tick costume 2000 to put in new lifters and pushrods on one side out of warranty. If it comes down to that I buy a new programmer. Take it back to stock and take it to the dealership
  4. UpsetProps
    Turns out I had 3 pushrods with excessive wear. Being replaced under warranty.
  5. RayVoy
    How can that happen in a new engine????? Years ago, the push rods would outlast the pistons.
  6. Chesters
    Glad warranty was good, hopefully they check the cam for you. Sometimes people don't look farther than what they originallyfind.
  7. JimmyA
    JimmyA Rockstar 4 Years 100 Posts
    I had mine replaced under warranty for my 5.3! The tuner doesn't have anything to do with mechanical issues! You are whoever should have no problems.
  8. UpsetProps
    When I spoke to them last night they said they would also be checking the camshaft.
  9. UpsetProps
    After further inspection they say the flywheel was making a squeaking noise and also needs to be replaced. Should have it back in a couple more days.
  10. UpsetProps
    Finally got it back. 3 pushrods, rocker arms and roller lifters with excessive wear replaced, and a cracked flywheel replaced under warranty :)
    She runs quiet now!
