Lifting my truck
Discussion in 'Lifted & Offroad Suspension' started by D-rek07, Dec 11, 2011.
  1. D-rek07
    D-rek07 New Member
  2. kburb
    Check out 4wheel parts, you should be able to get a couple of Procomps or Bilstiens for pretty close to that
  3. D-rek07
    D-rek07 New Member
  4. chevybulldog6
    chevybulldog6 Rockstar ROTM Winner 100 Posts
    I would say that longer shocks wont hurt but I would trust 4wheel parts before I would trust summit. I have had many dealings with 4wheel parts and they are very helpful. I would suggest calling and asking to speak with a mechanic. They will be able to tell you for sure. You could also just order the spacers and put them on. Your current shocks at most would limit the max travel which would not be a problem unless you are fully drooping the tire. If that is the case then you could order the shocks at a later date.
  5. tbplus10
    As a general rule any time you lift over 2" you need to replace the shocks.
    With the lift they get over extended when on the long end of the travel.
    When lowering the same rule applies because they start to bottom out.
    4WPW has some decent shocks at good prices, I've got a set on one of my trucks that I've been beating for 7 years and only had 1 failure that they covered no questions asked even though the shock had a dent in the side of the tube.
  6. D-rek07
    D-rek07 New Member
    So are you guys saying that it is okay to get the spacers without getting the shocks?
  7. tbplus10
    No were saying get new shocks, better off safe than sorry.
    Ever tried to drive a truck with a blown shock or two (or more)? It can be a dangerous handful.
  8. D-rek07
    D-rek07 New Member
    Ok, what are good ones that are under $50 dollars apiece? I am totally in the dark about this stuff. Thanks for the help.
  9. kburb
    look at the Pro Comps Es3000. Decent shock at a good price, Daystar also makes a shock for about 40 each. If your not offroading then either would work. I think i saw Rancho 5000 for under 50 also.
  10. aloxdaddy99
    4 Wheel Parts is offering Rancho 5000's for right at $50.
