    Join Today ~ It's Free
limited slip
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by 5speedsilverado, Apr 2, 2009.
  1. 5speedsilverado
    5speedsilverado New Member 1000 Posts
  2. Jimmiee
    Jimmiee New Member 1000 Posts
    That link points to Posi-Loks. These are not limited slip. If you want a locking differential then these will work although they are not as strong as a Detroit Locker, or an ARB . Once a wheel spins you are locked solid with one of these.
    If you want a limited slip go for the Eaton Posi which uses clutches.
  3. 5speedsilverado
    oh my dad had those on his jeep and they unlocked every once in a while, so i thought they would be good.
    so you were thinking this?? could you tell me the part number for the right one, because i know nothing about the axles that are under this truck other then the ratio
    http://www.jegs.com/p/Eaton/750876/10002/-1
  4. Jimmiee
    Your truck should have a 10 bolt with 30 spline axles. It should be this one:
    19559-01
  5. 5speedsilverado
    ok, thank you
  6. Seymour
    Seymour New Member
  7. Jimmiee
    The true track is is remarkable in that it biases the torque to the wheel with more traction.
