Load Capacity for 1999 Silverado 2500 ( not an HD)
Discussion in 'Chevy Truck Talk & GM News' started by bluebrick, Jul 5, 2012.
  1. bluebrick
    bluebrick New Member
    Any idea of how much weight I can carry in the bed of my 1999 Silverado 2500 ( this is not the HD model) with extended cab? Is there a chart or way to figure this out so that I don't break an axle or something? Thanks.
  2. PantheraUncia
    There should be some information in your owners manual. I am sure its posted online somewhere too.
  3. TexasTechRaider
    TexasTechRaider Rockstar 3 Years 500 Posts
    For that vehicle it's rated not to exceed 3100 pounds!
  4. PantheraUncia
    I took a look and found this:
    http://www.trailerlife.com/wp-content/uploads/2012/01/Trailer-Life-Towing-Guide-1999.pdf
    Keep in mind a few things..... This guy does not work for GM, so I would expect that these numbers are (close), but you would need the GM information to be sure.
    And the amount of weight that can be towed depend on a few things:
    • Engine size
    • If you have 2 wheel drive or 4 wheel drive
    • If it is a regular cab, extended cab or crew cab
    • if it is a long or short box.
  5. bluebrick
    Thanks evryone. Based on the tag information on the driver-side door, the rear axle has a capacity of just over 2000 #'s. I was able to haul a load of musroom compost at 2108#'s. Thanks again.
  6. Barnettamb
    Barnettamb Rockstar
    ive had quite a bit of weight over my load capacity of wood in my bed before and i just drove slow and careful and it was fine. chevys are built tough
