looking for some tech support
Discussion in 'Member Introductions' started by robb_03, Jun 5, 2010.
  1. robb_03
    robb_03 New Member
    Has any one taken a TBI 350 out of a late 80's truck and replaced it with a Carb small block? I am having fuel pump issues after putting 300 miles on the truck. The fuel pump runs when you turn the key on but aftger 15-20 seconds it turns off. The electric is shut off to the pump... confused on why it didnt do this right after the swap...
  2. murdog94
    Sounds like you might have lost your fuel pump relay? And the pump is supposed to shut off when it reaches the proper pressure until it needs more pressure. With out the injectors and computer monitoring everything there might not be signal being sent after it reaches the proper pressure.. Most people who swap these motors to carb, replace the electrical fuel pump with a mechanical or a low pressure fuel pump not mounted in the tank.. When they replace with either they take the pump out and run a pick up tube in place of the pump to keep their guage working.
  3. Eddie Z71
    Hi, and welcome to the site!:glasses: Glad to have you here! Looks like murdog94 has some great advice! Keep us posted! Good luck!
  4. retired2001
    Welcome to the GMTruckClub!
  5. robb_03
    robb_03 New Member
    Thanks for the Reply, I stuck with the in tank pump because I have two tanks and with about 6 MPG I want to stick with both tanks. I think I am just going to rewire the system adding a relay that comes from the ignition to my selector switch relay. I shouldnt have any problem that i can forsee. Whats you guys (and girls) advice?
