Loss of instrument panel lights
Discussion in 'GM Electrical Tech' started by horsch32, Jun 13, 2010.
  1. horsch32
    horsch32 New Member
    I'm new here, never really had a problem i couldn't figure out, until now. The instrument cluster lights quit working. so i took it out, tested the bulbs, found one was burnt out, replaced, still doesn't work. All the interior lights work. all the exterior lights work, radio works, abs, seatbelt, check engine etc... work. Don't know if those are on a different ground, or if they are where that would be. Any suggestions, or comments would be greatly appreciated. this is on a 96 silverado 1500
  2. TritonBoulder47
    Try the dimmer switch... You might have accidentally turned in down...
  3. voodoo 350
    voodoo 350 New Member
    yeah the dimmer or a taillight fuse being blown will cause your dash lights to go.
  4. horsch32
    horsch32 New Member
    Thank you. It was the parking lamp fuse that was blown. I just assumed that since the illumination fuse was good it was something else.
