Low speed ABS problem
Discussion in 'Lifted & Offroad Suspension' started by pipeguy, Mar 16, 2010.
  1. pipeguy
    pipeguy New Member
    Hi guys, I have been noticing a problem with my abs, it only happens ocasionally, when I am almost stopped my abs kicks in and it takes me 5 or 6 extra feet to stop. Is there a way to temporary dissable this feature until i take it to a shop? I have a 2002 sierra ext cab v8 with auto 4x4,and do you guys know what has to be replaced or cleaned? thanks.
  2. cobra2end
    cobra2end Rockstar 100 Posts
    My parents have a 99 1 ton that does the same thing. I havent been able to fig it out yet i have bled the breaks at least 5 times and my dad has done the same. not sure what it is but makes driving the truck kind of hard.
  3. Badbrad469
    Badbrad469 Rockstar 100 Posts
    i had the same problem with my truck. it's usually wheel speed sensor. mine ended up being the entire hub assembly itself because the wheel bearing was shot. when you buy the whole hub, it comes with a new wheel speed sensor. i replaced the hub, and problems were gone
  4. FireRed
    FireRed Rockstar 100 Posts
    Do like I have done pull the fuse until you get an answer, I also have a 2002 under the hood drivers side pull the cover off the box there is a 60AMP fuse marked ABS on the lid pull it and everything works perfect just no ABS.
