Low Voltage, Dimming lights.
Discussion in 'GM Electrical Tech' started by 03HeavyHalf, Feb 17, 2011.
  1. 03HeavyHalf
    03HeavyHalf Rockstar
    Alright, i got a 03 1500hd, 6.0. When i accelerate, the volt meter drops to about 9, my lights will be almost off, but when my truck shifts to the next gear the volts come back up and the lights get brighter again. I had the alternator checked but nobody can seem to say whats wrong with it. any help is awesome.
  2. murdog94
    something i would try is have the battery load tested, and check the chassis grounds to be sure they arent loose.
  3. dsfloyd
    these were things I was going to suggest. Also maybe (just a guess), the regulator on the alternator could be going bad. most new ones are internal so a new alternator would be needed. but do the original suggestion first as it is free.
  4. dualdj1
    dualdj1 Rockstar 100 Posts
    actually from what I was told most of the new ones are regulated by the computer (could be wrong, but that came from a GM mechanic). And barring grounding/other electrical issues, I could see that as being likely in your scenario.
    I think your most likely culprit though is a ground/connection issue.
  5. dsfloyd
    ha, guess I'm a little out of date on new. A day late and a dollar short. :rofl:
  6. dualdj1
    No Worries, the only reason I knew was I was digging for alternator compatibility info, and i think it's about mid/late 90's on they use external regulators (through the computer).
