lowering rear?
Discussion in 'Lifted & Offroad Suspension' started by 5speedsilverado, Jul 23, 2009.
  1. 5speedsilverado
    ok, my birthday is next month, and i was hoping to get a 2" lowering kit for the rear of my truck, if i do, will i have to get the front end aligned?
  2. adampaul1964
    Common sense tells me no since you are not changing the geometry of the front end, I think you'll be fine. But someone else may know different! :glasses:
  3. shurshot
    shurshot Rockstar 100 Posts
    I have lowered the rear of many of my trucks and NEVER had any problems. You should be fine.
    Good Luck!
  4. dsfloyd
    you shouldn't need to align since you are not changing anything up front
  5. 09lowrider
    09lowrider New Member
    the only way you would need an alignment is if you are going to be moving or changing the tie rods, if you dont adjust them you really wont need to do an alignment with a 2" drop.
    Are you going to do 2" drop all the way or a leveling kit? I'm not 100% sure on your style but if you drop the front with out drop spindles you might start to wear the inner parts of your tires faster, if that happens you need drops spindles or caster plates.
  6. 5speedsilverado
    ok, thanks, and 09lowrider, im just doing the kit on the rear for now
  7. reddedsilvy05
    reddedsilvy05 Rockstar
    im assuming your doing the 2" lowering shackles? if so, you will not need to align anything up front, i did this a couple of years ago and it never came out of alignment, you should be good. You will like the look much better too :great:
  8. 5speedsilverado
    yeah i think it will look good, i we had to get some sand for a path we are making, and we got my truck do do the dirty work:lol: the bed go filled with sand and gave me an idea of how it will look
    [​IMG]
    [​IMG]
    [​IMG]
