Lubing Suburban Rear Door Hinges
Discussion in 'General Chevy & GM Tech Questions' started by rs6er, Dec 3, 2009.
  1. rs6er
    rs6er Rockstar
    For as long as I've had my truck the rear doors make ungodly squealing noises when I open and close them. I've lubed anything I can see, but the noise seems to come from inside the doors. Any suggestions?
  2. osduck5
    osduck5 New Member
    Thank goodness I am not alone. I am ashamed to even open the doors when someone is around. They sound like they are a 100 years old. I did get some of the noise to go away by using white lithium grease spraying it onto the hinges and under the rubber boot that is around the hinge. I have to do this about once a month to kieep it from sounding like fingernails on a chalk board.
  3. TritonBoulder47
    White lithium grease has always worked for me... My '95 Tahoe was notorious for that...
  4. chew246214
    chew246214 Rockstar 100 Posts
    other stuff that works great for it is spray red grease can get it at most auto parts and if not find a marie shop they should have it... used to used it on my jeeps to lube the heim joints when they started to squeek, lasted and worked better then white it does not wash away when it gets wet... also on door latch assemblies it works wonders on... even the old 80's tailgat latches.. thought I had to replace.. sprayed clean with brakeclean then lubed up and they worked again... that sold me right there
  5. rs6er
    rs6er Rockstar
    Can't really see where to lube inside of door.
  6. D.sluff
    D.sluff New Member
    im sending the car out for paint this month and i have to strip the door pannels etc so the door jambs and everything can get painted so while im at it i figured id replace the seals, can u get the seals for the doors/windows/rear hatch from the dealer still, or is there anyplace online u can buy new seals?
