Major Vibration?!?!
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by z71roids, Mar 4, 2014.
  1. RayVoy
    Hey listen Bucko, I could walk away right now and you could pound sand for all I care.
    You can take the info provided and do something constructive with it, or complain that people trying to help are just showing off.
    I asked you "under what conditions are you using 4WD"...................that was to try and get an idea if you are abusing the drivetrain.
    I do not think that two t-cases in 100 k miles is normal; therefore, as you didn't answer my question, I assume you must be driving around in 4WD when conditions do not warrant it. Therefore, I assume you have damaged the front diff by abusing it.
    So, suck it up and buy a new one.
  2. Pikey
    I have had my truck on a hoist in gear and the front drive shaft spins. The case is always slightly engaged. This is with a "new" reman gm transfer case. I talked to my gear guy when I picked up my truck from having the front diff rebuilt yesterday. He said that the front drive shaft is always spinning. That is why when you have a bad carrier bearing in the front diff you can hear the hum while driving. the clutch packs are always engaged and is spring loaded to buffer any strain that may occur on the drivetrain.
    - - - Updated - - -
    Really? telling someone that I read something somewhere is not "showing of knowledge" in my opinion. FYI, if you delete or edit a post after it has been quoted the quote still stays with your original post in it. But, hey I will continue to try to post useful information for members of this site. You can continue to do whatever you are doing. I tend to try to research things and use data to backup my advice, not fly by the seat of my pants. And yes, a spinning front driveshaft that has 1/16" of play because of a broken yoke strap will vibrate like crazy.
  3. z71roids
    z71roids New Member
    I very rarely use 4x4.. I may have used it two or three times in the last year... its not the transfer that is the problem its working fine now..
    - - - Updated - - -
    im not trying to be a hassle, not used to all this stuff in the newer models. Hell for all I know nowadays it could have been a bad wiring harness making it vibrate like crazy.. (just kidding) but yeah, just trying to get her up and going again good to have a second opinion in anything.
    - - - Updated - - -
    That wasn't me who said that... im not here to argue with anyone just looking for info, but like I said 4x4 was used maybe two or three times since may and only when needed.. If I don't need it I don't use it gas is too exspensive anyways.
    AND in addition to everyone helping me, there is no unusual noise or anything.. Im going to go ahead and replace the straps and u joint tomorrow to see if that will do me any justice
  4. Pikey
    just a heads up, if it is the front diff.. I am not trying to "show my knowledge" but I just got my truck back yesterday from the gear shop. $640 for a rebuild of the front diff. But, I have to say, if it is shaking that badly then whatever it is should be pretty obvious when you start poking around. any lateral play in a driveshaft is a bad thing.
    - - - Updated - - -
    I don't think [MENTION=54249]RayVoy[/MENTION] was referring to you. he was referring to the other poster who made a negative comment because I posted a spec.
  5. z71roids
    z71roids New Member
    Yeah I haven't had any time to poke around and check due to rain and snow but as soon as it drys up a little ill see if I can locate the problem, if now ill bring it to my cousins shop and put it on the lift to see whats going on. Thanks for the help pikey.
  6. Pikey
    no problem :great: let us know what you find out!
  7. RayVoy
    Sorry, I did think it was you and I reacted. I didn't realize it wasn't you until I checked in this morning.
    Good luck on the planned repairs.
  8. j cat
    the forum member did say 4X4 not working after he just had this repaired...that is not very clear what all that means. I would bring the vehicle back to the person who screwed up this repair. If it was just fixed now and no 4X4 , and a harsh vib something was not put back correctly..
    forums like these are not a substitute for a shop manual to properly repair these issues and the less a person knows about auto repair the less these forums can help with complex repairs like the 4 WD drive train components.
    the forum here does have much good info and help to direct confused owners with repair procedures , tools required to complete repairs or just figure out if the repair shop screwed them..
  9. Pikey
    I believe that he rebuilt the T-case himself.
  10. j cat
    so with this being done by him and if he did not use an OEM shop manual for his vehicle , to properly repair the T-case I can believe that this is not working properly.
    if he does use the manual after a few try's he will be an expert on this .
