Manual mode?
Discussion in 'Chevy Truck Talk & GM News' started by chilln, May 8, 2012.
  1. chilln
    chilln New Member
    My new 2500HD has a function to switch to a manual transmission with + & - buttons to shift through the gears. I used to drive stick and understand that you can get better fuel millage. Is this what that function is for? Also I tow a camper from time to time would it be useful to use that mode while towing?
  2. Sierraowner5.3
    not sure how much it will help with mileage, its more so to give you more control when towing. if the transmission is shifting alot, you can switch it to manual and do it yourself, or set it in manual and pick a gear and it wont shift any higher, M4 selected and the transmission will auto shift from 1-4, you can also do it yourself.
    hope this helps.
    Alex
  3. RayVoy
    I use it to keep the transmission from shifting into the overdrive gears, sometimes, all you need is the first 4 gears.
    The PCM is tuned to shift at the best point for conditions and load, with economy always a consideration. Just my 2 cents, but I don't think you can improve the equation by shifting yourself.
  4. steved
    steved Former Member
    Its just buttons that do what the selector did in previous versions...if you put it in "M-4", the transmission will only use the first four gears, "M-5" it uses only the first five gears. I find it really handy on little two land back roads where you don't really ever hit 35mph, keeps the trans from shifting out of its useable range..."M-4" seems to be the sweet spot, especially in tow/haul on those goat paths.
    Its not a "manual shift" that you start in first and shift "manually" through the gears...
