Mass airflow sensor
Discussion in 'Performance & Fuel' started by wmc0461, Oct 15, 2010.
  1. wmc0461
    wmc0461 New Member
    Would putting an aftermarket airflow sensor be beneficial?
  2. 06MonteSS
    06MonteSS Rockstar 100 Posts
    nooooo!
    do not change the MAF sensor... the stock MAF is plenty, they can handle 550+ hp anyway...
    aftermarket MAF's fool the pcm into thinking it's running leaner than it really is, and screws things/tunes up....
    do not change it...
  3. rutroe
    rutroe New Member
    I second that!
  4. Bigbomber
    I didn't know that would happen if you changed it,thanks for the heads up!
  5. murdog94
    X3!!! there is no need for it!
  6. 2COR517
    Since we're discussing MAF, stay away from oiled filters like K&N. They will foul your MAF.
  7. Bigbomber
    I believe that if you don't soak your K&N filter in oil your MAF will be fine.
  8. AL3X
    AL3X Rockstar
    reguardless of what you do to those kn but eventually it'll touch your maf sensor after time which is why i went with an AEM DRYFLOW
  9. ZSI52
    If you don't soak the filters then you'll have absolutely zero problems with it. If you do get to much oil on it, then just go get some maf cleaner.
  10. 2COR517
    Read on one of these forums that a guy working in an engine shop could always tell when an engine had been running a K&N by the scoring in the cylinder walls.
