Measuring ATF after Vette Servo
Discussion in 'General Chevy & GM Tech Questions' started by Silverado1500, Feb 10, 2011.
  1. Silverado1500
    Silverado1500 Rockstar 100 Posts
    im planning on doing the vette servo this weekend and i was wondering how to measure the correct amount of fluid to put back in after the mod.
    which ATF is recommended? dexron IV or VI? i am unsure of what kind of ATF is in it now because it was changed when i bought it used
  2. stephan
    I don't think putting the Vette servo is going to change the amount of fluid your tranny requires so I would just replace the approximate amount you drain out & then check with the normal procedure. If you want to get it down to the gnats azz, measure exactly how much you drain out & put that much back in & then double check when you get it warmed up. I don't know which type Dextron your trans takes because you didn't list the year or transmission.
  3. Silverado1500
    2000 1500 silverado and i think i have the 4l60e
  4. Z71_guy
    As far as i know GM recommends putting dex VI in all now, check with your local dealer i know we have been doing dex VI in most trucks from 2000 and up, when ever the customer wants to pay for the additive
