    Join Today ~ It's Free
Misfire solved!!!
Discussion in 'General Chevy & GM Tech Questions' started by vncj96, Jun 20, 2009.
  1. vncj96
    vncj96 New Member 1000 Posts
    Well it wound up being a gummed/carbon coated exhaust valve for the #4 cylinder (could not fully close), so both heads are being pulled to check the rest of the valves and then check the heads for warping and cracks, figure I have that much labor into it already might as well add a few more hours to save me the money that could be spent if anything else failed. So now as it stand have had ALL injectors pulled, inspected and cleaned. Will have new set of plugs and distributer put in as well. Top end is/will be spotless and ready for another 100,000!!
  2. Springthing
    Springthing New Member 1000 Posts
    Ya, see, Jason... just like I said.. glad I got you in the right direction...
    :rolleyes:
    but glad you got things figured out and actually thinking a few steps ahead.
  3. vncj96
    If I would have taken it in in the first place I would have saved myself $175, and some busted knuckles, but on the other hand I would have been pissed if it was something I could have done.
  4. phoebeisis
    phoebeisis Active Member 1000 Posts
    JASON,
    Yes, it is nice to finally get a pain in the butt problem fixed.Any idea why #4 got gummed up? Bad plug wire-bad spark plug, bad injector bad luck?
    Congrats
    Charlie
  5. vncj96
    Not for sure yet, they havent got that far into the head, they have just identified its that valve and its cruddy lookin, but will keep everyone posted
  6. ct9a
    ct9a New Member 1000 Posts
    Glad to hear you got it figured out.
  7. Jimmiee
    Jimmiee New Member 1000 Posts
    Glad you found the problem!
  8. 2ToNe04
    2ToNe04 New Member 1000 Posts
    nice, its easy to pull off the heads anyways. Should run like a beast when theyre back on.
