miss and rich gas
Discussion in 'General Chevy & GM Tech Questions' started by bowtie boy, Sep 15, 2012.
Newest Photos
  1. bowtie boy
    bowtie boy New Member
    I've replacedall thus common things. The map sensor has not yet been done and the fuel pump but everything else. Help bowtie lovers
  2. Chris Miller
    Chris Miller New Member 100 Posts
    What's the year and model?
  3. bowtie boy
    1995 Chevy 305 pu
  4. Skippy
    Skippy Member 100 Posts
    Are you getting an actual "Rich" reading code, or is this diagnosed another way?
  5. moogvo
    moogvo Moderator 1000 Posts 100 Posts
    Map and o2 sensors are responsible for fuel mixture on these trux. Check vacuum lines. Are you getting a check engine light?
  6. dipstick
    dipstick New Member 100 Posts
    Check fuel pressure 9 to 14 psi..also might be the coolant temp sensor.
  7. moogvo
    Pit would be more helpful if you could tell us more... What are the circumstances that make it happen? Engine hot, cold, all the time? Under load, under acceleration, etc. the more info you can provide, the more we can give good advice.
