Miss on 99 Suburban 5.7 Vortec 180K
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by dhpgac, Nov 26, 2011.
  1. dhpgac
    dhpgac New Member
    Ok, I just had my intake manifold gasket replaced that was leaking. Thanks for everyones input, I had this miss that started before it was fixed, when I notice it most is when I floor it or hit the highway cruising along. It's like for a fraction of a second the engine has a miss are no power, like the spark was turned off or a jerk. Could this be the injectors ( ran injector cleaner already ), ignition, no codes come up or service engine light. The map sensors had been replaced by the other owner, but I have one of those K&N type air filters in the intake box. Any thoughts, new plugs installed 500 miles ago.
    :grrrrrr:
  2. janikphoto
    janikphoto Rockstar 3 Years 100 Posts
    hmmmm... no code yet? Have you checked the line to the intake butterfly to make sure it isn't hitting something at WOT?
  3. Boonduff
    Check the fuel pressure. These trucks need to have at least 60 psi at all times or you will experience all kinds of drivability problems including hesitation and misfires.
  4. Caddiac
    Could be a sticking injector. Don't Worry, it will tell you if there is an issue that the ECM cannot control.
  5. longbeach
    longbeach New Member
    I have a 97 K2500 with the 5.7 vortec and I am having the same issue. I have had the truck about 6 months and have not had a chance to really investigate yet. If I find anything I'll post....Wayne
  6. Quikfire
    Quikfire Member
    Im tracing a similar issue and think that I have it nailed down to a corroded distributer cap. No mechanic here, but going through the process of elimination and it led me to pulling the distributer cap and found it unpleasant looking.
    99 GMC Suburban 5.7
  7. Caddiac
    Good catch! That sucker will run fine until one day and boom! It will skip like heck. Got me coming back from the coast. Long drive skipping - LOL. Be careful tightening the screws! The distributor ears are plastic and break easily.
  8. dhpgac
    dhpgac New Member
    Still having the problem, took out the K&N type filter, back to paper and cleaned the MAF sensor with the CRC cleaner for MAF. The prior owner had changed it before. Today I finally got a error code P0171 bank one too lean, have not replaced fuel filter yet, so with this error code any ideas to narrow it down?
  9. Boonduff
    Have you checked the fuel pressure? My 97 would throw a lean or misfire code every once in a while and it turned to be low fuel pressure. Swapped in a new fuel pressure regulator and it solved the problem.
  10. dhpgac
    dhpgac New Member
    Would it be a regulator with a bank 1 & 2 code? Could it be erg valve, bad injector, l changed fuel filter & ran GM Injector, still get the 171 & 174 codes
