Discussion in 'General Chevy & GM Tech Questions' started by jyocum39, Jul 21, 2012.
  1. jyocum39
    jyocum39 New Member
    Would a bad intake gasket cause an intermittent miss? The truck misses every once in a while.
  2. Skippy
    Skippy Member 2 Years 100 Posts
    Certainly could, but it's unlikely at higher RPM. You'll most likely see the problem (if your intake gasket is resulting in an air leak) at idle. It'll be rough and hesitate. If you're missing periodically, the first thing I'd check is the spark plugs. If you're leaking oil or antifreeze into the cylinder, you may also be fouling the plugs, which would also result in a misfire. Again, check the plugs.
  3. jyocum39
    jyocum39 New Member
    Thanks man i will check the plugs. I am going to go ahead and change the gasket cause i read there prone to failure.
  4. Skippy
    New parts definitely are less prone than old stuff. *Grin*
