More Power
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Landslide, May 28, 2012.
  1. Landslide
    Landslide New Member
    I'm going to be installing a new trans in my 90 Burb soon and after that I would like to upgrade my ignition system, any suggestions on coils, wires, distributors and the like, I've seen quite a few different products, I have gotten great advice from you folks before and I'm sure someone out there has the right answer or at least a good suggestion.
  2. carmantx
    carmantx Rockstar
    I use MSD products when possible, and have heard some good from Mallory. I never use Accel stuff.
    If your wires are old, you will get the best improvement for the dollar with those. If your coil output is good, and your engine is stock, you will just be getting newer stuff if you replace distributor and coil. You could recurve your distributor to get the mechanical advance in quicker, and that would help it perform better.
  3. Strino78
    Strino78 Member
    My recommendation is a MSD Blaster Coil, a set of good 8mm wires, and a new distributor cap and rotor button. Throw in a set of new plugs, and you'll be all set. I wouldn't recommend a stand-alone ignition system like an MSD, Crane or Accel... unless you have a power plant under the hood that "really" needs the RPM Limit/Step controls the boxes offer; they don't show any improvements on a stock engine.
