My CVX's aren't hitting lows real good...?
Discussion in 'Audio, Video & Gadget Tech' started by zachmilz, Mar 6, 2011.
  1. zachmilz
    zachmilz Rockstar 100 Posts
    I have two 12" Dual 2-ohm CVX subs powered by a Hifonics HFi2500 at two ohms. They should be getting around 700 RMS a piece from that amp and they're in a prefab box from Amazon. I'm pretty sure it's the box, but these subs just don't hit lows. It sounds really airy and they flex a LOT when I put it on a low song turned up. Each sub has 1.5 cu ft of air space in the box which isn't that much. I want to have a good range of bass, but I'm playing songs with higher frequencies to make them sound good. I'm not going to lie, these subs get LOUD, but I know there has to be more potential out of them. Any recommendations? Should I just make a bigger box?
  2. Enkeiavalanche
    Enkeiavalanche Loving the Outdoors Staff Member 4 Years ROTM Winner 5000 Posts
    Do you have the Amp set right? What head unit are you useing? What Ga wire do you have for the power and ground? What size fuse by the Batt? Did you up grade the wire going from your alt to the Batt?
  3. zachmilz
    I have the gain turned up 1/4 on the amp, the rest of the settings are correct. I'm using a Kenwood KDC-MP145. I have 0 gauge power and ground with a 250A amp fuse by the battery and I haven't done the big 3.
  4. Enkeiavalanche
    I would get a head unit thats 4 volt out and upgrade the other wires..
  5. zachmilz
    What would the 4V output do? And you mean do the big 3?
  6. Enkeiavalanche
    Higher volt outputs give a cleaner sound and a bit more volume to your amps.. Up grade the Alt wire and ground from the body to frame..
  7. zachmilz
    Okay, thanks. Do you think it will help the low frequencies? Also, do you change the input sensitivity on my amplifier for that?
  8. Enkeiavalanche
    Yes if you do a 4 volt output then turn up the gain.. But only if you have 4 volt output...
  9. zachmilz
    Okay, thanks!
  10. sstoner911
    What does that box look like? I would go with more air space...I think 1.5 is min for those subs.i have seen guys pushing 300 rms to cvx's and they pound.
    The enclosure is 70% of the recipe.IMHO.
