My latest 1960 Land Rover project (Lots of Pics)
Discussion in 'Photo & Video Gallery' started by dsfloyd, Sep 5, 2013.
  1. dsfloyd
    Its been a little while since I have been in here. I have been swamped at work lately.
    Mods, if this is more appropriate in the coffee shop sub forum feel free to move it. I has been GM'd though as it has a GM alternator, carb, and regulator (see its practically a GM:rofl:)
    It does a whole lot more sitting than anything but I would like to get it out more often. Here are some exterior views from a few years ago.
    So the latest project was to replace the clutch that went out a couple years ago. But as with everything plenty of things popped up as I was making my way to the clutch, this also lead to other projects along the way. I think overall with over 50 years of caked on oil and dirt I did easily 10 hours of clean up for every hour of actual mechanic work:grrrrrr:. I tried cleaning as much as possible while I was tearing into everything.
    First step was to remove the fuel tank (gas doesnt last very well sitting for a couple years.) and clean it out.
    IMG_20130713_102334_855.jpg IMG_20130713_155512_693.jpg IMG_20130714_190025_781.jpg
    Next The interior body panels needed to be removed to access everything.
    IMG_20130721_153957_244 (577x1024).jpg IMG_20130721_162642_055 (1024x577).jpg IMG_20130721_165203_237 (1024x577).jpg
    Drivelines needed to be removed and cleaned. New ujoints were also installed at this point, which was the only thing I was able to source locally from napa autoparts, everything else always has to be ordered. Yay 53 year old british vehicles:no:
    IMG_20130711_175813_114 (1024x577).jpg IMG_20130711_175805_402 (1024x577).jpg IMG_20130711_175753_911 (1024x577).jpg IMG_20130714_182241_153.jpg IMG_20130714_182250_746.jpg IMG_20130715_195026_808 (1024x577).jpg
    Time to start pulling the Tranny. Its British so everything leaks. Output shaft seals were replaced as well as all levers getting cleaned and painted. New mounts also installed. Clutch installed at this point as well:party:. I did give up cleaning the tranny more after a couple days of wire wheeling and scrubbing and scraping. New pan gaskets made for the tranny and transfer case.
    IMG_20130726_222429_109 (577x1024).jpg IMG_20130726_222616_313 (1024x577).jpg IMG_20130801_094839_486 (1024x577).jpg IMG_20130801_094826_436 (1024x577).jpg IMG_20130729_165005_951 (1024x577).jpg
    The emergency brake is a transmission brake. Since the output shaft seal was leaking I had to clean this and make it all pretty too.
    IMG_20130729_174151_325 (1024x577).jpg IMG_20130730_114415_923 (1024x577).jpg
    Clutch slave also replaced
    IMG_20130724_181216_162 (577x1024).jpg IMG_20130724_182131_270 (1024x577).jpg
    To Be Contd...............................
  2. Enkeiavalanche
    There is a guy in my town who puts Buick V 6's in them he has a few..
  3. McClintoc
    Judging from that fourth pic, it's just a horn on wheels! :p
    Awesome project though!
  4. dsfloyd
    Time to start re-assembly:great:
    IMG_20130801_134431_946 (1024x577).jpg IMG_20130801_175046_182 (1024x577).jpg IMG_20130801_232826_627 (1024x577).jpg
    Drivelines were next. The Pinion seals were also replaced. Unfortunately I ran out of time to pull the full differentials to clean and paint (as well as make new gaskets for the halves).
    IMG_20130811_172730_195 (1024x577).jpg IMG_20130811_172746_305 (1024x577).jpg IMG_20130811_181756_340 (1024x577).jpg
    Time to put all the interior back together. New boot and knob kit was installed (bought along time ago but never put on as I wanted to wait until I started to restore)
    IMG_20130819_013420_781 (577x1024).jpg IMG_20130819_013452_398 (1024x577).jpg
    The other stuff that got done during this time as well was new pan gasket on oil pan (pic above). I also replaced the aftermarket electric pump with a new mechanical one (backing plate painted black but not in done yet in pic.
    The stock oil filter was removed and a new spin on conversion was installed. The oil filler neck was also removed, cleaned and painted with new gaskets. Eventually I will get the wires cleaned up.
    IMG_20130711_175708_198 (1024x577).jpg IMG_20130711_175734_638 (1024x577).jpg IMG_20130719_194906_288.jpg IMG_20130802_191009_610 (1024x577).jpg IMG_20130806_170820_058 (1024x577).jpg
    Finally, I think, I replaced the brake/clutch reservoir. Went to bleed the system, clutch was fine but brakes kept getting air in it. pulled the master cylinder apart but then got no suction so I just got a new one (havent installed it yet).
    IMG_20130806_171300_220 (1024x577).jpg IMG_20130806_174156_328 (1024x577).jpg
    Well, the clutch works now:great:, but brakes dont for the time being:gasp:. Got it running after all fluids changed, but the carb needs some major tuning, as I had to crank the idle screw to get it to idle with the choke off, but now the choke idles super high. Will probably source that part to someone. After running for about 5 minutes all 3 of the rubber sections of the exchaust hangers decided to melt/brake so the entire rear of the exhaust dropped:grrrrrr:. Always 2 steps forward 1 step back with this thing. Hopefully the new seals and gaskets will hold back some of the fluids now too.
    - - - Updated - - -
    yep much more common on the east coast. My grandfather purchased this from the factory. Kind of a family heirloom as my dad gave it to me when I turned 18. We had already gone and switched it to negative ground from positive and then later rewired the whole thing.
    Ha, yep put on a horn that plays "dixie" of dukes of hazzard fame.
  5. McClintoc
    Nice! Time to repaint it orange!
  6. dsfloyd
    Don't think it will be as quick as the general lee, but I may just have to buff out the aluminum body and go for the blinding effect.
  7. tbplus10
    Is that a capstan style front winch?
    She still looks good no matter how much corrosion, grime, and faded paint she has.
  8. dsfloyd
    Yes it is. It can be hand cranked as well. I love the thing (when its working right), next summer I will go through and make the big project brakes and suspension. Will probably go back to wheels and tires that are closer to stock. It currently has 27x8.5 R14 and the stock size was 7.00x16 (some came with 15" rims). Grandfather did a bit of hunting and it was a way to gear it down even more than it is with just wheels and tires. Kinda wish the stock wheels would have been kept somewhere as its difficult to find the bolt pattern. Looking at going with 235/85/16 eventually to make it a little more road friendly as now it screams at 50mph.
  9. jsmith4816
    jsmith4816 Rockstar 4 Years 100 Posts
    Nice project. Keep it going. I hope to one day do an older Chevy, but that will have to wait until I am a little older, lol
  10. phoebeisis
    Heck-that is COOL!!
    There was a TV show-late 1950's-early 1960's called WHITE HUNTER.
    Set in Africa-guess it was actually filmed in California with stock Africa footage
    In it the hero-played By Rhodes Reason- drove a LAND ROVER!!
    Yeah it was cool
    He used to end or start?the show saying White Hunter with Rhodes Reason!!
    Yeah loved that Land Rover because it was in that show-and the nature show-Wild Kingdom?? that was always going to Africa-catching Rhinos etc-usually in a land Rover!!
    Maybe tagging them-giving them shots-or getting them for Zoos
    Cool Truck- with World's Coolest Name "LAND ROVER"
    Guess its electrics are so simple the lucas electrics can be upgraded easily ??GM alternator-sure beats Lucas Prince of Darkness!!
    Probably could put an old GM straight 6 in it if it came to it.
