namron67
Discussion in 'Performance & Fuel' started by namron67, Jul 15, 2012.
  1. namron67
    namron67 New Member
    1995 GMC Sierra 4X4 Carburated, Won't idle, have to pump accelerator to rev. engine. when holding throttle 1/2 open engine acts like it is starving for fuel, installed new fuel filter.
    This is my first post.
  2. dpeter
    Welcom to the forum. What carb do you have and can you verify fuel pressure at the carb. Tell us a little more about your set up as it doesn't sound like stock.
  3. namron67
    namron67 New Member
    I was completely wrong. It is not a carburetor, it is a 5.7L TBI (Throttle Body injector) I don't have the pressure testing gauge, but I will get one and let you know. Thank you
  4. RayVoy
    Is the Check Engine Light on? Do you have any codes in the PCM?
  5. vncj96
    Clean up your AIC, its a free fix and many times its the culpret
  6. namron67
    namron67 New Member
  7. namron67
    namron67 New Member
    The fuel pressure barely registered. Tomorrow I will drop the fuel tank. I hope this message gets to you.
    Thank you for your help
  8. Jimmeh
    Let us know if the new pump fixes the problem!
  9. dpeter
    Sounds like you're on the right track. I also hope you have or had some help for that tank!
