Need Help with my new truck
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by x1LSUTigerfan, Jun 24, 2010.
  1. x1LSUTigerfan
    x1LSUTigerfan Member
    Ok yall ijust got an 04 silverado ext cab z71 monday and today my 4 wheel drive service light came on :grrrrrr:, its the push button 4x4, and now the 4x4 wont work, i have a hypertech programmer and it is giving me two trouble codes a u1000 code and a BO159 code. Can somebody pleaseeee help me
    ---------- Post added at 09:49 PM ---------- Previous post was at 08:23 PM ----------
    can anybody help??
  2. mus99gt
    mus99gt Rockstar 100 Posts
    I am not sure what the fix is, but I did find this list of DTC codes.
    Diagnostic Trouble Code (DTC) List - Vehicle
    DTC
    Descriptor
    DTC 001
    DTC 002
    DTC 003
    DTC B0012, B0013, B0014, B0016, B0017, or B0018
    Right Front/Passenger Frontal Deployment Loop Circuit
    DTC B0022, B0024, B0026, B0042, B0043, or B0044
    Left Front/Driver Frontal Deployment Loop Circuit
    DTC B0028, B0029, or B0030
    Right Front/Driver Side Deployment Loop Circuit
    DTC B0040, B0041, or B0045
    Left Front/Driver Side Deployment Loop Circuit
    DTC B0051
    Deployment Commanded
    DTC B0053
    Deployment Commanded with Loop Malfunctions Present
    DTC B0077, B0078, B0079, B0080, B0081, or B0082
    Side Impact Sensor (SIS) Circuit
    DTC B0100, B0101, B0102, B0103, B0104, or B0105
    Electronic Frontal Sensor Circuit
    DTC B0145, B0428, or B3531
    Auxiliary HAVC Actuator Circuit
    DTC B0159 or B0164
    Air Temperature Sensor Circuit
    DTC B0174, B0179, B0510, or B0515
    Discharge Air Temperature Sensor Circuit
    DTC B0183 or B0188
    Sunload Sensor Circuit
    DTC B0229, B0414, B0424, B3761, or B3770
    HVAC Actuator Circuit
    DTC B0248, B0263, B0268, B0408, or B0418
    DTC B0248, B0263, B0408, or B0418
    DTC B0283
    Electric Rear Defrost Circuit
    DTC B0414, B0424, B3761, or B3770
    DTC B0540
    Speedometer Circuit
    DTC B0560
    Tachometer Circuit
    DTC B0770
    [COLOR=blue !important][COLOR=blue !important]All [COLOR=blue !important]Wheel [/COLOR][COLOR=blue !important]Drive[/COLOR][/COLOR][/COLOR] (AWD) Indicator Circuit
    DTC B0775
    Four Wheel Drive High Range (4HI) Indicator Circuit
    DTC B0780
    [COLOR=blue !important][COLOR=blue !important]Four [COLOR=blue !important]Wheel [/COLOR][COLOR=blue !important]Drive[/COLOR][/COLOR][/COLOR] Low Range (4LO) Indicator Circuit
    DTC B0785
    Two Wheel Drive High Range (2HI) Indicator Circuit
    DTC B0790
    Transfer Case Neutral Indicator Circuit
    DTC B0951
    Dimming Circuit
    DTC B1000
    ECU Malfunction
    DTC B1001
    Option Configuration Error
    DTC B1004
    Keep Alive Memory (KAM) Reset
    DTC B1007
    Electronic Control Unit (ECU) Performance
    DTC B1009
    EEPROM Checksum Error
    DTC B1017
    Output Driver Module (ODM) 1 Performance
    DTC B1023
    Integral Switch Performance
    DTC B1372
    Device Ignition 1 (ON and START) Circuit Low
    DTC B1375
    Device Ignition 3 (ON) Circuit
    DTC B1420
    Device Voltage
    DTC B1440
    Power Mode Master Input Circuits Mismatch
    DTC B1480
    Battery Rundown Protection Circuit Malf
    DTC B1550
    Mirror Left Front or Right Front Select Switch Circuit
    DTC B1720
    Mirror Up and Down Control Switch Circuit
    DTC B1721
    Mirror Left and Right Control Switch Circuit
    DTC B1723
    Mirror Motor Control Circuit 1 Performance
    DTC B1724
    Mirror Motor Control Circuit 2 Performance
    DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, or B1820
    Power Seat Switch Circuit
    DTC B1825, B1850, B1860, B2355, B2365, or B2375
    Seat Position Sensor Circuit
    DTC B1830, B1835, B1840, B1845, B2075, B2080, B2085, B2090, or B3905
    Lumbar Switch Control Circuit
    DTC B2425 or B2430
    Seat Heater Circuit
    DTC B2435 or B2440
    Seat Back Heater Sensor
    DTC B2455
    Cellular Phone Microphone Circuit
    DTC B2470
    Cellular Phone Antenna Circuit
    DTC B2476
    Cellular Phone Select Service Switch Malfunction
    DTC B2482
    Cellular Phone Select Service Switch Range/Performance
    DTC B2483 or B2484
    Global Positioning System (GPS) Sensor Circuit
    DTC B2527
    Front Fog Lamp Circuit Low
    DTC B2530
    Front Foglamps Control Circuit
    DTC B2540
    Rear Foglamps Control Circuit
    DTC B2550
    Backup Lamps Control Circuit
    DTC B2575
    Headlamp Control Circuit
    DTC B2580
    Headlamp High Beam Control Circuit
    DTC B2585
    Parklamp Control Circuit Malfunction
    DTC B2610
    Passenger Compartment Dimming 1 Circuit
    DTC B2615
    Passenger Compartment Dimming 2 Circuit
    DTC B2620
    Display Dimming Input Circuit
    DTC B2625
    Display Dimming Pulse Width Modulation (PWM) Output Circuit
    DTC B2645
    Ambient Light Sensor Circuit
    DTC B2697
    Headlamp Washer Request Circuit
    DTC B2725
    ATC Mode Switch Circuit Malfunction
    DTC B2734
    Control Module Internal Performance
    DTC B2815
    Steering Wheel Controls Illegal Resistance Value
    DTC B2947
    Security System Sensor Power CKT Low
    DTC B2948
    Security System Sensor Power CKT High
    DTC B2957
    Security System Sensor Data Circuit Low
    DTC B2958
    Security System Sensor Data Circuit High
    DTC B2960
    Sec Sys Sensor Data Incorrect but Valid
    DTC B2961
    Key In Ignition Circuit Malfunction
    DTC B3031
    Key Decoder Device in Assem Learn Mode
    DTC B3055
    Key Not Present
    DTC B3060
    Unprogrammed Transponder Identification Code Received
    DTC B3801
    Passenger Compartment Lamp Request Circuit
    DTC B3802
    Parklamps Request Circuit
    DTC B3808
    Rear Door Lock Relay Circuit
    DTC B3809
    Rear Door Unlock Relay Circuit
    DTC B3810 or B3811
    Washer Relay Circuit
    DTC B3819
    Left Rear Power Window Up Relay Circuit
    DTC B3820
    Left Rear Power Window Down Relay Circuit
    DTC B3821
    Window Lockout Circuit Low
    DTC B3822
    Right Rear Power Window Up Relay Circuit
    DTC B3823
    Right Rear Power Window Down Relay Circuit
    DTC B3824
    DTC B3935
    Transponder Authentication Error
    DTC C0221-C0227
    [COLOR=blue !important][COLOR=blue !important]Front [COLOR=blue !important]Wheel[/COLOR][/COLOR][/COLOR] Speed Sensor Circuit
    DTC C0229
    Drop Out of [COLOR=blue !important][COLOR=blue !important]Front [COLOR=blue !important]Wheel[/COLOR][/COLOR][/COLOR] Speed Signals
    DTC C0235-C0237or P0609
    Rear Wheel Speed Sensor Circuit
    DTC C0238
    Wheel Speed Mismatch
    DTC C0241-C0254
    EBCM Control Valve Circuit
    DTC C0265 or C0266
    EBCM Relay Circuit
    DTC C0267 or C0268
    Pump Motor Circuit Open/Shorted
    DTC C0269 or C0274
    Excessive Dump/Isolation Time
    DTC C0271-C0273, C0284
    EBCM Malfunction
    DTC C0279
    Powertrain Configuration Not Valid
    DTC C0281
    [COLOR=blue !important][COLOR=blue !important]Brake [COLOR=blue !important]Switch[/COLOR][/COLOR][/COLOR] Circuit
    DTC C0283
    Traction Switch Shorted to Ground
    DTC C0287, P1644, or P1689
    Delivered Torque Circuit
    DTC C0290 or C0292
    Lost Communications With PCM
    DTC C0291
    Lost Communications With BCM
    DTC C0297
    Powertrain Configuration Data Not Received
    DTC C0298 or P1571
    Powertrain Indicated Traction Control Malfunction
    DTC C0300
    Rear Speed Sensor Malfunction
    DTC C0305
    Front Speed Sensor Malfunction
    DTC C0306
    Motor A or B Circuit
    DTC C0321
    Transfer Case Lock Circuit
    DTC C0327
    Encoder Circuit Malfunction
    DTC C0359
    [COLOR=blue !important][COLOR=blue !important]Four [COLOR=blue !important]Wheel [/COLOR][COLOR=blue !important]Drive[/COLOR][/COLOR][/COLOR] Low Range (4LO) Discrete Output Circuit
    DTC C0374
    General System Malfunction
    DTC C0379
    Front Axle System
    DTC C0550
    ECU Malfunction
    DTC P0101
    Mass Air Flow (MAF) Sensor Performance
    DTC P0102
    Mass Air Flow (MAF) Sensor Circuit Low Frequency
    DTC P0103
    Mass Air Flow (MAF) Sensor Circuit High Frequency
    DTC P0106
    Manifold Absolute Pressure (MAP) Sensor Performance
    DTC P0107
    Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
    DTC P0108
    Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
    DTC P0112
    Intake Air Temperature (IAT) Sensor Circuit Low Voltage
    DTC P0113
    Intake Air Temperature (IAT) Sensor Circuit High Voltage
    DTC P0116
    Engine Coolant Temperature (ECT) Sensor Performance
    DTC P0117
    Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
    DTC P0118
    Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
    DTC P0120
    Throttle Position (TP) Sensor 1 Circuit
    DTC P0125
    Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
    DTC P0128
    Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
  3. mus99gt
    DTC P0131 or P0151
    HO2S Circuit Low Voltage
    DTC P0132 or P0152
    HO2S Circuit High Voltage
    DTC P0133 or P0153
    HO2S Slow Response
    DTC P0134 or P0154
    HO2S Circuit Insufficient Activity
    DTC P0135, P0141, P0155, or P0161
    HO2S Heater Performance
    DTC P0137 or P0157
    DTC P0138 or P0158
    DTC P0140 or P0160
    DTC P0171 or P0174
    Fuel Trim System Lean
    DTC P0172 or P0175
    Fuel Trim System Rich
    DTC P0200
    Injector Control Circuit
    DTC P0218
    Transmission Fluid Overtemperature
    DTC P0220
    Throttle Position (TP) Sensor 2 Circuit
    DTC P0230
    Fuel Pump Relay Control Circuit
    DTC P0300
    Engine Misfire Detected
    DTC P0315
    Crankshaft Position (CKP) System Variation Not Learned
    DTC P0325
    Knock Sensor Module Performance
    DTC P0327 or P0332
    Knock Sensor Circuit
    DTC P0335
    Crankshaft Position (CKP) Sensor Circuit
    DTC P0336
    Crankshaft Position (CKP) Sensor Performance
    DTC P0341
    Camshaft Position (CMP) Sensor Performance
    DTC P0342
    Camshaft Position (CMP) Sensor Circuit Low Voltage
    DTC P0343
    Camshaft Position (CMP) Sensor Circuit High Voltage
    DTC P0351-P0358
    Ignition Coil Control Circuit
    DTC P0420 or P0430
    Catalyst System Low Efficiency
    DTC P0442
    Evaporative Emission (EVAP) System Small Leak Detected
    DTC P0443
    Evaporative Emission (EVAP) Purge Solenoid Control Circuit
    DTC P0446
    Evaporative Emission (EVAP) Vent System Performance
    DTC P0449
    Evaporative Emission (EVAP) Vent Solenoid Control Circuit
    DTC P0452
    Fuel Tank Pressure Sensor Circuit Low Voltage
    DTC P0453
    Fuel Tank Pressure Sensor Circuit High Voltage
    DTC P0455
    Evaporative Emission (EVAP) System Large Leak Detected
    DTC P0461
    Fuel Level Sensor Performance
    DTC P0462
    Fuel Level Sensor Circuit Low Voltage
    DTC P0463
    Fuel Level Sensor Circuit High Voltage
    DTC P0480
    Cooling Fan Relay Control Circuit
    DTC P0483 or P0493
    Cooling Fan System
    DTC P0495
    Cooling Fan Speed High
    DTC P0496
    Evaporative Emission (EVAP) System Flow During Non-Purge
    DTC P0502
    Vehicle Speed Sensor (VSS) Circuit Low Input
    DTC P0503
    Vehicle Speed Sensor (VSS) Circuit Intermittent
    DTC P0506
    Idle Speed Low
    DTC P0507
    Idle Speed High
    DTC P0522
    Engine Oil Pressure (EOP) Switch Circuit Low Voltage
    DTC P0523
    Engine Oil Pressure (EOP) Sensor Circuit High Voltage
    DTC P0526
    Cooling Fan Speed Sensor Circuit
    DTC P0530
    Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
    DTC P0562
    System Voltage Low
    DTC P0563
    System Voltage High
    DTC P0567
    Cruise Control Resume Switch Circuit
    DTC P0568
    Cruise Control Set Switch Circuit
    DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610
    ECU Malfunction
    DTC P0608
    Vehicle Speed Output Circuit
    DTC P0621
    Generator L-Terminal Circuit
    DTC P0622
    Generator F-Terminal Circuit
    DTC P0641
    5 Volt Reference 1 Circuit
    DTC P0650
    Malfunction Indicator Lamp (MIL) Control Circuit
    DTC P0651
    5 Volt Reference 2 Circuit
    DTC P0654
    Engine Speed Output Circuit
    DTC P0705
    Transmission Range (TR) Switch Circuit
    DTC P0706
    Transmission Range (TR) Switch Performance
    DTC P0711
    TFT Sensor Circuit Range/Performance
    DTC P0712
    Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
    DTC P0713
    Transmission Fluid Temperature (TFT) Sensor Circuit High Input
    DTC P0719
    [COLOR=blue !important][COLOR=blue !important]Brake [COLOR=blue !important]Switch[/COLOR][/COLOR][/COLOR] Circuit Low Input
    DTC P0724
    Brake Switch Circuit High Input
    DTC P0740
    TCC Enable Solenoid Circuit Electrical
    DTC P0741
    Torque Converter Clutch (TCC) System-Stuck Off
    DTC P0742
    TCC System Stuck On
    DTC P0748
    Pressure Control Solenoid Circuit Electrical
    DTC P0751
    1-2 Shift Solenoid Valve Performance
    DTC P0752
    1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear
    DTC P0753
    1-2 Shift Solenoid Circuit Electrical
    DTC P0756
    2-3 Shift Solenoid Valve Performance
    DTC P0757
    2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear
    DTC P0758
    2-3 Shift Solenoid Circuit Electrical
    DTC P0785
    3-2 Shift Solenoid Circuit Electrical
    DTC P0894
    Transmission Component Slipping
    DTC P1106
    Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
    DTC P1107
    Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
    DTC P1111
    Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
    DTC P1112
    Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
    DTC P1114
    Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
    DTC P1115
    Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
    DTC P1125
    Accelerator Pedal Position (APP) System
    DTC P1133 or P1153
    HO2S Insufficient Switching
    DTC P1134
    HO2S Transition Time Ratio Sensor 1
    DTC P1137
    HO2S Circuit Low Voltage During Power Enrichment Sensor 2
    DTC P1138
    HO2S Circuit High Voltage During Decel Fuel Cut-Off (DFCO) Sensor 2
    DTC P1171
    Fuel System Lean During Acceleration
    DTC P1258
    Engine Coolant Overtemperature - Protection Mode Active
    DTC P1380
    Misfire Detected - Rough Road Data Not Available
    DTC P1381
    Misfire Detected - No Communication with Brake Control Module
    DTC P1481
    DTC P1482
    Cooling Fan Speed Output Circuit
    DTC P1484
    Cooling Fan System Performance
    DTC P1514
    Throttle Body Performance
    DTC P1515
    Control Module Throttle Actuator Position Performance
    DTC P1516
    Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
    DTC P1518
    Throttle Actuator Control (TAC) Module Serial Data Circuit
    DTC P1574
    Stoplamp Switch Circuit
    DTC P1626
    Theft Deterrent Fuel Enable Signal Not Received
    DTC P1630
    Theft Deterrent Learn Mode Active
    DTC P1631
    Theft Deterrent Start Enable Signal Not Correct
    DTC P1632
    Theft Deterrent Start Disable Signal Received
    DTC P1637
    DTC P1638
    DTC P1810
    TFP Valve Position Switch Circuit
    DTC P1860
    TCC PWM Solenoid Circuit Electrical
    DTC P1870
    DTC P1875
    [COLOR=blue !important][COLOR=blue !important]Four [COLOR=blue !important]Wheel [/COLOR][COLOR=blue !important]Drive[/COLOR][/COLOR][/COLOR] (4WD) Low Switch Circuit
    DTC P2108
    Throttle Actuator Control (TAC) Module Performance
    DTC P2120
    Accelerator Pedal Position (APP) Sensor 1 Circuit
    DTC P2121
    Accelerator Pedal Position (APP) Sensor 1 Performance
    DTC P2125
    Accelerator Pedal Position (APP) Sensor 2 Circuit
    DTC P2135
    Throttle Position (TP) Sensor 1-2 Correlation
    DTC U1000 and U1255
    Class 2 Communication Malfunction
    DTC U1001-U1254
    Lost Communication with XXX
    DTC U1300, U1301, or U1305
    Class 2 Data Link Shorted
    DTC U1500
    Inter-device Dedicated Bus 1
  4. 04-silverado
    04-silverado Rockstar 100 Posts
    I don't know why your 4WD won't engage, and the DTCs you've posted appear to have little to "offer" as to what this may have to do with 4WD.
    Perhaps the U1000 is the more pertinent -- as an indication that you need to inspect cables for damage and/or disconnect-clean-reconnect any exterior cable connections?
    AT any rate, here's some info regarding DTCs from my ALLDATADIY.COM subscription:
    Then too, there's this one:
  5. taldridg
    taldridg New Member
    Had similar issue, wouldn't change to 4x4, Auto...always stayed in 2WD. Searched around and appears this is commonly due to poor solder connections in the control module (where the buttons are). Mine is 2001, no DTCs were set, nothing in DIC.
    Took the module out of dash, re-soldered all the connections and reinstalled. Been working fine since.
