Need help with sig
Discussion in 'Announcements & Feedback' started by Brews, Apr 10, 2012.
  1. Brews
    Brews Rockstar
    I have the pic on my computer but I'm having problems getting it to load for my sig. Thanks in advance for the help!!
  2. UpsetProps
    UpsetProps Member 2 Years 100 Posts
    Click on Settings at the top right of the page.
    Go down on the left to Edit Signature.
    Go to the bottom where it says Signature Picture.
    You can either upload from your PC or from another website.
    After that select Insert Signature Picture and it should drop it in.
  3. Brews
    Brews Rockstar
    It gives me this error - This is not a valid image file. The extension for the picture is .bmp.
  4. donyms
    Change the image to JPG, JPEP, or GIF and it will work fine. :glasses:
  5. Brews
    Brews Rockstar
    Thx for the help. How do I make the picture larger?
  6. UpsetProps
    If you set the sig pic the way you did it autosizes to that size.
    If you want a larger one you will need to host the image somewhere online and link it is your sig using the [ IMG ] tags.
  7. Brews
    Brews Rockstar
    This gives me invalid file. [​IMG]
    ---------- Post added at 03:35 PM ---------- Previous post was at 03:28 PM ----------
    So it works in the post but not in the sig.
  8. UpsetProps
    [MENTION=24891]Brews[/MENTION]
    I just dropped your picture you linked into my sig temporarily. Just click the little picture frame that looks like a tree that is called Insert Image. Paste the link and it should show up.
    I will remove your truck from my sig when you see this.
  9. Brews
    Brews Rockstar
    Thx for your help bud!!
  10. donyms
    If you want your picture bigger as allot of us have you can upload it to http://picturepush.com/upa this is a free site, you do not even need to sign up. Once you upload your picture or pictures they will give you a link to them. After you have sized it, copy the link to that picture and then paste it in your signature by going to settings / edit signature / under signature upload paste the link into option 1 box then choose upload, then insert Signature picture and your done. My picture is 640 X 300 pixels and 62.25 KB the limit is 75 KB I hope this helps. :glasses:
