Need help
Discussion in 'Chevy Blazer Forum (GMC Jimmy)' started by traverskidude, Apr 24, 2012.
  1. traverskidude
    traverskidude New Member
    Hey guys need some help.
    Looked all over to find out how I can make my 04' Chevy Blazer LS from a 4x2 to a 4x4? No one can give me a straight answer on what parts i need to buy or even point me in the right direction. Any help is appreciated.
  2. dsfloyd
    most of the time (especially with newer vehicles) It is cheaper and less of a headache to buy a 4x4. Front suspension is typically completely different. need transfer case, shifters, computer etc.
  3. Pikey
    I completely agree. The entire front end would have to be replaced. New transfercase, possibly transmission, any computer changes, wiring harnesses! If you really wanted to do it you could try to find a truck that has been totaled in the rear. Then start pulling parts off of that one and put it in yours. Including computer. I don't know that the proper brackets are even in place to make that swap.
  4. msfrost
    msfrost New Member
    I am trying to locate the oxygen sensor at Bank2 Sensor1, on my 2001 Chevy Blazer LS. I do not know what to look for.
  5. tbplus10
    On this particular truck you'll need to do a SAS (Solid Axle Swap), not a job I'd recommend for a backyard mechanic.
    You'll need a short tailshaft transmission, transfer case, front axle, (the front axle and r/r axle gears might need to be swapped to get matching gears), you can get by with the ecm you have but youll need an older model manual transfer case to do that, if you try to use a newer transfer case your gonna need a new ecm and wiring harness along with designing a wire harness to bypass a couple sensors that work with the front axle.
    Unless you have advanced mechanical and fabrication skills and this is a second vehicle you can park for a while to complete the build I'd recommend either paying the $4000-$7000 a shop will want to complete the project or trading up to a 4x4. Truthfully in the end you'll be money ahead trading upto a 4x4.
    ---------- Post added at 03:44 PM ---------- Previous post was at 03:38 PM ----------
    Passengers side exhaust manifold, the first sensor on that side going downstream on the exhaust.
    Controls cylinders 2, 4, 6.
