Neutral safety switch replacement
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dgill, Aug 3, 2009.
  1. dgill
    dgill New Member
    I have a 2000 Silverado, auto and I'm about to replace the neutral safety switch. I noticed there are two bolt holes that are elongated to hold it to the trans and will allow the swtch to rotate a bit. Does anyone know if I have to adjust the switch once installed? Never had to replace one in all my 65 years so I'm not sure. Thanks in advance.
  2. retired2001
    I've never had to either, Dan. Good luck!
  3. Jimmiee
    I believe they are preset so you just bolt it on in the 'N' position. The first time you shift it it will break a small plastic tit that holds it into position. Once this happens it becomes adjustable. If it's out of adjustment it's easy to adjust. If it won't start in 'N' then you just have to move it till it does.
  4. grimreapersshadow
    grimreapersshadow Rockstar 100 Posts
    no you shouldnt have to adjust any thing just a straight bold on item
