Neutral safety wire color?
Discussion in 'General Chevy & GM Tech Questions' started by skipray, Aug 1, 2009.
  1. skipray
    skipray Member
    I'm installing a car alarm/remote start in my automatic suburban(keep people from stealing tools).
    Does anyone know what color the neutral safety wire is? I have two yellow wires,one of the yellow wires
    has two wires inside it(1 green,1white).Any help would be appreciated.I'll post pics of install when I'm done.
  2. Jimmiee
    What year? Are you referring to the wires that go to the ignition switch or the neutral switch?
  3. skipray
    skipray Member
    it's a 95 5.7 suburban .The wire that lets you start the truck when in park or neutral.
  4. unplugged
    My 93 is different, but my Chilton's shows the 95 diagram and there appears to be only one yellow wire going towards the ignition switch and a purple wire going towards the starter. It makes mention that on the auto trans version, the ns switch is incorporated into the reverse light switch and is mounted on the trans.
  5. Jimmiee
    Yes, this is correct. Here's a more detailed snapshot:
  6. skipray
    skipray Member
    Thanks! I kinda figured something wasn't right.I got it to start finally.It was funny,I didn't have the brake wire(cut off) hooked up yet and couldn't shut it off.:lol:Now I have to figure out what polarity the door locks are.Good thing I have plenty of fuses.I'll probably spend the next few days finishing up on this.
  7. skipray
    skipray Member
    Well,after four days I finally got the system wired together and running properly.The biggest problem
    I had during the whole installation was finding accurate diagrams for my suburban.I found three sets
    of wiring diagrams online.All of them had one or two mistakes.I contacted the seller of the system on ebay.He offered to replace the unit free of charge(which was pretty cool).I didn't think it was a problem with the system,so I kept going over everything.I finally went to my old desktop and dug out my mitchell's repair cd for the truck.(I should have done that from the start!).Once I connected everything according the the mitchells,the system worked.
    I should have researched aftermarket systems more before I bought this one.Not that this one is bad,but there aren't any good installation or troubleshooting help sites for it.
    Tomorrow I am going to solder all my connections and put the the panels back in.
    The first and LAST remote start I ever put in.
