new guy here, i got a code 171 and 174
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by fnoblitt, Nov 11, 2011.
  1. fnoblitt
    fnoblitt New Member
    my 2000 silverado has been a little slow to start up latey. check engine light came on today. has a code 0171 and 0174, i looked them up and it's a lean right and left bank. i'm not that great on diagnosing problems so i did what i knew. i changed the fuel filter(was very dirty), cleaned the map sensor screen(just a little dusty), cleaned the throttle body, and washed& dryed the reuseable air filter(very dirty). changed the oil and filter while i was at it. cleared the codes and drove the truck. the check engine light came on again. so now what might it be? i had the fuel pump replaced about 3 months ago.when it was taking a while to start.
  2. 99'HEARTBEAT
    Trouble Codes P0171 and P0174 are telling you there's an Issue(Running Lean)Check for a Vacuum Leak and then if O.K....Check the 02 Sensor's before the Cats....
  3. fnoblitt
    fnoblitt New Member
    i replaced all 4 o2 sensors about 6 months ago when i had a calitic code. could these go bad or get dirty this soon ?
  4. 99'HEARTBEAT
    I would Double Check the Connections, also what Brand of 02 Sensor's did you Install, also have you Checked the Fuel Pressure??
  5. fnoblitt
    fnoblitt New Member
    i got them from rock auto,made overseas,can't remember the brand. i'm going outside now to pull them, and see what they look like
  6. 2COR517
    Those codes and your driving symptoms are classic for low fuel pressure. Get a gauge and test it.
  7. fnoblitt
    fnoblitt New Member
    i've never done that before. is it a simple procedure to do ? if it is, i'll go down to autozone and see if they have a gauge that will work on my truck
  8. Aftahoe
    Aftahoe New Member
    Hello. I have a similar question. I have a 2001 Tahoe with the 5.3 engine. I had a leaky fuel pressure regulator or that was giving me a P 300 code. While replacing that, I checked my fuel pressure and it was showing 48psi. I replace the fuel pump and the filter. Shortly after start up, I was showing a P171 and 174 code. Does anyone have any suggestions? I would certainly appreciate any help.
  9. xPosTech
    xPosTech Epic Member 5+ Years 1000 Posts
    You'll have much better results if you start a new thread. This one is 4 years old.
    For your problem - 0171 and 0174 both basicly say that the mixture is too lean in bank 1 and bank 2. Since it's both banks you probably have a vacuum leak in the intake system. It might be a broken vacuum line, intake manifold gasket or possibly low fuel pressure.
    Ted
  10. 99'HEARTBEAT
    Ted....Just a Heads-up the Member has Started a New Thread.....I was just getting ready to Remove his Reply Above in this Thread...when you Replied......:)
