New Head Unit
Discussion in 'Audio, Video & Gadget Tech' started by groceryman, Apr 5, 2012.
  1. groceryman
    groceryman New Member
    Replacing my factory head unit i have bose and onstar which interface is most everyone using is PAC the best or what others has people been using. I will also be looking for a steering wheel control adapter interface.
  2. sstoner911
    sstoner911 New Member
    PAC is the most common.
  3. zigger215
    zigger215 New Member
    PAC will have both solutions for you.
  4. SurrealOne
    SurrealOne Former Member
    Regarding steering wheel controls, I've used both the PAC SWI-JACK and the Metra Axxess ASWC to retain my factory steering wheel controls with a new head unit. Of the two, I recommend the Metra Axxess ASWC as it's a) less work to install in terms of things you must access on the truck and wires you must find, b) self-programming, and c) reliable. I can say none of those things for the PAC SWI-JACK as it pertains to use with a Kenwood head unit.
    Like you I have an 04 that had Bose and OnStar. I completely removed the Bose system so I needed the chime module and used PAC OS-2CBOSE, which worked (and is still working) just fine.
  5. Jeremy09LTZCrew
    Jeremy09LTZCrew New Member
    Good thread. I'll hopefully be upgrade my head unit, and crutchfield recommends the PAC. I'll have to look into the other you mentioned Surreal. Ease of installation is definitely a factor to consider.
  6. groceryman
    radio.jpg Just got in new jvc head unit it a world of difference sounds great
  7. SurrealOne
    Good work! That came out nice and clean. :)
  8. groceryman
    Only problem was my Metra Axxess ASWC was bad could not get it vto work got it off ebay. I contacted the seller they are going to send me another one.
