New owner, a few questions
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by kennya, Apr 30, 2012.
  1. kennya
    kennya New Member
    Another update. The check engine light came back on the other day. Was able to take it to AutoZone and get the codes read, they were p0446 and p0455. I got it into the dealer later that day and they did the smoke test and could find no leaks anywhere. The reset it and I was off. Came back on yesterday...ugh. Called and taking it in on Wednesday, hoping they figure it out this time.
  2. mfleetwood
    Hope they are able to find and permanently fix the problem. Does your truck still have low enough miles to where this stuff is covered under warranty? If so, at that's a help.
  3. 08_rado_rocker
    08_rado_rocker Member 2 Years 500 Posts
    Glad someone introduced you to this.. i have personally done the DIC upgrade on my 08 and it works fantastic, all plug-n-play and only took a total of literally 3 minutes TOPS to install, just need two (one can be used) small screwdrivers to get the headlight/dimmer switch block off the old panel.
    Also, welcome to the club and congrats on the purchase!
    :sign0021:
  4. kennya
    kennya New Member
    Truck has 48k miles, might still be in luck. Figure i will have the truck there around 3:30 or so. Sure hope they figure it out this time. After i am done there i am dropping it off for a spray in bedliner. Gonna order the DIC button panel this evening or tomorrow.
  5. aloxdaddy99
    Congrats on the new truck. Hope you get the issues fixed.
  6. kennya
    kennya New Member
    Ok, well, it's the evap canister. They can put in a new one and have me back on the road for $665.00. Please tell me the part number and that I could do this myself....
  7. JayBee
    JayBee New Member
    Man that just sounds like it is too expensive to me. Maybe I am wrong and hopefully others here have experience with this and can lead you in the right direction. Hopefully you can do it yourself. Good luck!
  8. Pikey
    Check out some websites like GMpartsdirect. I found it for about $120 there
  9. kennya
    kennya New Member
    After much discussion with the wife and a lot of research, just going to have the dealer take care of it. Taking it down there in about an hour...
  10. SurrealOne
    That's probably wise from a warranty perspective...
