new owner audio question
Discussion in 'Audio, Video & Gadget Tech' started by irbya, Jan 10, 2009.
  1. irbya
    irbya New Member
    Close please
    Close please
  2. 04sierracrewcab
    Are the dash boards the same?
  3. irbya
    irbya New Member
    dash is a little diffrent but holes are exact same it looks like
  4. 04sierracrewcab
    If it will fit It should be able to be work, Im not sure how the wiring would go?..
    Some of our "Audio Guys" will chime in later. :great:
  5. JMoney02
    You can check the plug ends by checking each and comparing them for the features of each of the radios. They both will fit the insert, but you will need to see if there is seperate connector for the Nav. system because I believe that there is. Is to 07' model Nav system as well, if so then both plugs are indentical and work on each of the units. The cradles are the same for each, its just a matter of the power for each of the devices...
  6. identityPRS
    identityPRS Rockstar 100 Posts
    did his truck have bose?? if so, it just might work, if not, its gonna be complicated. also i doubt your truck has the GPS antenna in it, however, the DVD and radio should work if the plugs are the same.
