New Tires...Old Spare
Discussion in 'Wheels & Tires' started by AzDragonLord, Jan 26, 2011.
  1. AzDragonLord
    AzDragonLord Rockstar
    I expect my factory P245/70R-17 tires to need replacing within the next year, and I'm entertaining the idea of getting a slightly larger tire (the Hankooks here). Would I be able to keep and use the original spare even though it's slightly smaller? I know I shouldnt' mix tire sizes, but if it's for "limited use only", I could save some serious $$ by not buying a 5th tire.
  2. AzDragonLord
    Nobody knows if that small difference in tire size will be an issue?
  3. Bigbomber
    I can't see why it would be a problem,you see cars with those donut spares on all the time.As long as you fix your tire quick ,i'm sure it's not going to do any damage to your truck.
  4. silveradotrailblazer
    If your truck has a rear locker than you can't mix the rear tires as they would be rotating at differant speeds. My '05 has a locker and when I got a flat tire I moved the right front to the rear and put the spare on the front (pain in the ass).
  5. AzDragonLord
    I don't know if I do or not. What would happen if I did?
  6. silveradotrailblazer
    You could tear up the rear end because the rear is locked and the smaller tire is wanting to turn faster than the taller tire.
  7. o3gerber
    o3gerber Rockstar 100 Posts
    as long as you run the spare on the front and dont put it into 4 wheel drive you will be fine. if you have a locker in the rear and run two different size tires you could brake a axel
  8. AzDragonLord
    Well I don't want to break anything! I'll keep them all the same when the time comes.
    Thank you all. :)
  9. silveradotrailblazer
    When you buy your new tires buy a CHEAP tire for the spare, the same size as the others.
  10. dpeter
    GREAT idea! I have the same concern. My spare has never hit the ground, wonder if they would swap for a good used one of the new size for the spare.
