new to GMC can anyone help?
Discussion in 'General Chevy & GM Tech Questions' started by k_lakey, Mar 11, 2009.
  1. k_lakey
    k_lakey New Member
    i just got a 1990 gmc stepside 4x4 with a 5.7 a 4' lift and 33's on it and when i drive it feels realy slugish... its got a magnaflow cat back... take off is really slow.. can anyone help?
  2. GaryL
    Welcome to the site.
    Do you know what gears you have in it? It sounds like you may not have enough gearing for the size tires you are running.
    You might also check the timing, if it is off it could cause sluggishness.
  3. bry2500
    I would agree about the timing, 33's are not significantly over sized so IMO they are less of a factor here. Still if the gearing has been changed from stock before then they become more of an issue.
  4. retired2001
    Welcome to the site. You didn't mention, but considering the age of the truck you might want to check out the catalitic converters. They can cause a lot of issues when they go bad. Just a thought.
  5. Jimmiee
    Make sure to have it scanned for codes. There may be a code stored in memory that can point to the power loss.
  6. k_lakey
    k_lakey New Member
    i dont know what gears are in it... i think stock
  7. k_lakey
    k_lakey New Member
    and the catalitic converters looks new
  8. ct9a
    An easy way to check the cat is by temperature. I picked up a cheap laser thermometer at Harbor Freight when I thought mine was going out.
  9. k_lakey
    k_lakey New Member
    how would i do this?
  10. Jimmiee
    Easiest way is to take it to Autozone. They will scan it for you for free.
