New Transmission Cooler....
Discussion in 'Towing & Trailer Tech' started by 99'HEARTBEAT, Jul 13, 2011.
Thread Status:
Not open for further replies.
  1. ChevyBoy2009
    ChevyBoy2009 Rockstar 4 Years 500 Posts
    Ive been checking on Ebay and can find the exact one i need...but maybe im blind:neutral:
  2. XS ive
    XS ive Rockstar 100 Posts
    The only nervous part I had of install was cutting the hard line to install a compression fitting. I had a tubing cutting in my tool box and it made short clean work of it. The hard lines slide and clip into the OEM cooler and new EAD fittings. I just looked at the new fittings for a few minutes to figure the clips out. A small screwdriver popped them right out. Very easy! If you are using the bypass, you will be using rubber hose to connect.
    I also purchased the bypass with the TruCool, but I did not install it. I read somewhere that my 2008 with the HD tow package may have an internal bypass. I also just replaced the OEM cooler with the TruCool so the fluid will run through the radiator first anyway. I guess when the cold weather arrives I'll find out if I need it. Seeing as my truck is a "garage queen" for most of the winter I don't forsee a problem.
    If you have any problems feel free to contact me, or 99, or mfleet.
  3. 99'HEARTBEAT
  4. XS ive
    TruCool Max LPD47391 (without bypass)
    TruCool max LPD4739 (with bypass)
    I see 99 is a faster typer! lol
  5. ChevyBoy2009
    How would i know if i have the HD Towing package??...it gets pretty cold up here in Iowa in the winter and those early morning hunting trips are quite chilly,maybe i should get the bypass?
  6. XS ive
    If you have the OEM trans cooler, you have the tow package. I'm not sure if that has a bypass though.
    I believe the bypass is for applications which completely bypass the radiator. Maybe someone can shed some light on that?
  7. ChevyBoy2009
    I do have the OEM cooler
  8. SurrealOne
    Mfleetwood answered that earlier in the thread. To wit, he said:
    Hope that helps...
  9. aloxdaddy99
    I just got the cooler and mounting kit. How long did it take you all to install yours? Just wondering how much time I should set aside.
  10. 99'HEARTBEAT
    It took me around an Hour and 15mins, from start to finish, I would say give yourself at leased 2 hours, Mfleetwood and XS live would be able to give you a much better time fame, as to how long your going to need to do the install....as all of you have NNBS Trucks....
Thread Status:
